Author Topic: 550 - NO SPARK  (Read 6484 times)
Offline pamcopete
  • Ride. Enjoy. Life is simple
    • CB750Ignition
Re: 550 - NO SPARK
« Reply #25 on: June 15, 2014, 01:48:43 PM »
Now just wondering about setting the timing . I did do a slight top end rebuild, the cylinder bores have been honed and new rings. Iv been doing a lot of reading about proper break in procedures and from what I gather I shouldnt really let it idle for any period of time, sooo how do I work around this to get the timing right?
Put a giant fan in front of the engine. It doesn't take that long to set the timing. Start with the plate at the mid point for the upper slot. That is very close to correct timing. Also, now that you have the primary wiring sorted out, double check that you have cylinders 1 - 4 connected to one of the coils and cylinders 2 - 3 connected to the other coil.
Offline Anton
Re: 550 - NO SPARK
« Reply #26 on: June 15, 2014, 02:11:44 PM »
I thought I had sorted that out when I reversed the way I originally had the green wires going to the coils?
Re: 550 - NO SPARK
« Reply #27 on: June 15, 2014, 02:31:50 PM »
I believe he means at the spark plugs.
Offline Anton
Re: 550 - NO SPARK
« Reply #28 on: June 15, 2014, 02:48:51 PM »
Ahh jeeze :-[ I understand. I had wires from one coil going to 1 and 2, and 3 and 4 on the other coil.
Thanks for that.
Re: 550 - NO SPARK
« Reply #29 on: June 15, 2014, 02:55:04 PM »
That could be your timing issue.
Offline Anton
Re: 550 - NO SPARK
« Reply #30 on: June 15, 2014, 08:29:59 PM »
Yup that solved it, starts up first kick, no back fire!
now just have to figure out why the oil light isnt turning off while its running :-\. I just want to ride it already!!
Offline pamcopete
    • CB750Ignition
Re: 550 - NO SPARK
« Reply #31 on: June 16, 2014, 03:37:25 AM »
Did you add some oil after you did the overhaul?
Being as your last issue was with the new wiring harness, that is the first place I would look. Remove the wire from the oil pressure switch and see if the light goes out. If it does, then the problem is either no oil or a bad oil pressure switch. If the light does not go out when you remove the wire from the oil pressure switch, then it's the wiring. In either case, do not run the engine for more than a few seconds until you fix the problem.
« Last Edit: June 16, 2014, 03:42:16 AM by pamcopete »
Offline Anton
Re: 550 - NO SPARK
« Reply #32 on: June 16, 2014, 10:09:26 AM »
Yea she's topped up with oil, so that light should turn off within the first few seconds of having the motor running?
Offline Anton
Re: 550 - NO SPARK
« Reply #33 on: June 16, 2014, 07:14:42 PM »
Got it! the switch wasnt screwed down all the way.
Thanks for walking me through this guys, I really appreciate it.
I have a few loose ends to tie up and I think shes ready to roll sometime this week. Keeping my fingers crossed .
Ill post some photos when she rolling.
Thanks again!
Re: 550 - NO SPARK
« Reply #34 on: June 16, 2014, 07:15:55 PM »
good news. You are on your way, keep us posted.
Offline pamcopete
    • CB750Ignition
Re: 550 - NO SPARK
« Reply #35 on: June 17, 2014, 04:13:39 AM »
Thanks again!
Before you go on that maiden ride, I suggest that you check around town for a tow truck company who has experience retrieving motorcycles. Get their rates and range of operation and stay in that zone. Just a thought, but a lot can go wrong with that first ride after all the work you have done to the bike. And, stay off of the Lions Gate bridge for a few days until all the bugs are fixed!  ;D
