Author Topic: Just ordered Stainless Bolts... Anything I should know?  (Read 1693 times)
Offline Prez1967
  • Adding lightness...
« on: June 15, 2014, 11:34:13 AM »
Just ordered stainless bolts from Jim @ http://www.metrocast.net/~spillane/index_002.htm
Anything I should know about the engine case bolts before I replace them one at a time?
Anti-seize will be used for sure.
Offline RJ CB450
Re: Just ordered Stainless Bolts... Anything I should know?
« Reply #1 on: June 15, 2014, 02:03:14 PM »
Mostly, be careful torquing them down.  They are a socket head machine screw, so easy to over-torque and just rip the threads out.  Make sure you clean all the internal threads very well before installing.
Other than that, stainless and socket heads are far superior to the zinc plated crosshead and hexhead used originally.  Double check the lengths.  Sometimes the lengths are to include a washer, so see if you need to place new ones to prevent bottoming out.
74 CB450 K7 Supersport, 82 CB650sc Nighthawk, 1982 CBX 1000, 2015 Tiger XCx.... And some ol minibike with a 5hp Briggs.
ken65
« Reply #2 on: June 15, 2014, 02:29:35 PM »
a little anti-seize aswell helps stops  metal reaction.
« Reply #3 on: June 15, 2014, 02:35:59 PM »
Only hand snug them. None of the side cover bolts/screws require anything more than 6-8# of torque.
+1.  I find using a small 1/4" ratchet lessons the chance of over torquing.
« Reply #4 on: June 15, 2014, 02:45:07 PM »
Yeah, you should know they will polish out to chrome consistency and shine. I sand them down if the surface is not smooth then take them to my polishing wheel. Oh yeah, I do it the easy way, I chuck each one up in my cordless Dewalt drill and turn the head against a sheet of sand paper then the buffing wheel on my stand.
Offline tlbranth
« Reply #5 on: June 15, 2014, 09:08:23 PM »
When you thread a stainless bolt into aluminum, be sure to use COPPER antiseize. This is per INOX recommendation.
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline Hon3ybadger
  • Someday it will run...
« Reply #6 on: June 16, 2014, 09:39:02 AM »
I did not do this. Thank you for the advise!
Offline SohRon
« Reply #7 on: June 16, 2014, 10:23:37 AM »
Copper - probably the worst thing you can do to your case with SS bolts. Anti-seize manufacturers (and most mechanical engineers worth their salt) recommend zinc, aluminum, or nickle for SS/aluminum interactions due to galvanic corrosion. Leave the copper stuff for your spark plugs and exhaust studs.
If Copper was a ubiquitous cure-all, manufacturers wouldn't have bothered formulating other types, especially those aimed specifically at Al/SS interactions.
« Last Edit: June 16, 2014, 10:29:25 AM by SohRon »
Offline tlbranth
« Reply #8 on: June 16, 2014, 10:36:59 AM »
I've posted this before but here it is again. INOX makes stainless fasteners for motorcycles. Read their recommendation for yourself. I tend to think they know what they're talking about since it's their business.
http://inoxbolt.co.uk/zen/index.php?main_page=page&id=2#anti_seize
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline SohRon
« Reply #9 on: June 16, 2014, 11:24:27 AM »
Looks to me that Inox are distributors rather than manufacturers:
Our A2/A4 fasteners are mostly of European origin
Products machined from T316/303/431 alloys are made by local machinists
Bolts come in, you order them, bolts go out. It's obvious from his recommendation for copper anti-seize that his understanding of galvanic corrosion and the galvanic table is limited, at best.
Talk to any mechanical engineer about using copper, stainless and aluminum together and you'll get an earful. They just don't mix. It's why you shouldn't use copper and aluminum wiring in your house, for instance; in fact, there are special connectors that are required if you must do so for some reason.
Again, if Copper was meant to be a ubiquitous cure-all, manufacturers wouldn't have bothered formulating other types, especially those aimed specifically at Al/SS interactions. Frankly, I'd rather listen to the anti-seize manufacturers in regards to what to use; it's their business, after all!
I'm not sure why it's so tough to consider anything but copper... it's just as easy to get the right stuff and not take chances!
But, it's your bike - do whatever you want to it.  :o ;D
« Last Edit: June 16, 2014, 11:26:02 AM by SohRon »
Offline tlbranth
« Reply #10 on: June 16, 2014, 01:44:17 PM »
Well at my age I can't pee all that far so I'm out
Don't own a Vanagon
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
« Reply #11 on: June 16, 2014, 01:55:52 PM »
Glad I read this thread before my build.
http://forums.sohc4.net/index.php?topic=94686.0;nowap
Offline RJ CB450
« Reply #12 on: June 16, 2014, 02:15:14 PM »
This is why I dislike threads about science.  Lack of references :p  As for the never use copper, disagree.  But also in that thread, there are bound to be things that are used instead.  Like that Permitex stuff for aviation.  I don't feel like looking it up, but there is more to that than just the base metal so take that info for what you will.
On the topic of galvanic corrosion, that is another whole bag of worms.  True, aluminum and copper together will react in a bare and dry environment.  However, the stainless steel or whatever other material which would have even more of a cathodic/anodic reaction does even more.  Point is, add into thermic properties as well.  When you add stainless, the copper will break down before the aluminum.  Use nickel, the nickel and stainless form a barrier.  On top of that, if I remember my products correct, the anti-sieze is also non conductive helping to prevent the galvanic reaction as well.
Meh, too much science for a monday.  Suffice to say, there is alot more to antisieze compounds than two dis-similar wires twisted together.
Offline lucky
« Reply #13 on: June 16, 2014, 04:45:27 PM »
I agree. Never put copper next to aluminum!
Offline Accolay
« Reply #14 on: June 16, 2014, 06:43:29 PM »
So, what antiseize product should I buy?
1977 CB550F
« Reply #15 on: June 16, 2014, 06:53:15 PM »
Want some popcorn while you wait the answer?!!
Offline Prez1967
« Reply #16 on: June 16, 2014, 06:56:11 PM »
Blue Loctite?
