Author Topic: 1975 cb550 first build (project gaijin)  (Read 6072 times)
Offline adventure_prone
« on: June 17, 2014, 09:46:00 PM »
Hello all.
Welcome to my first build, I'm a machinist and welder for the air force so I thought I'd try and put those skills to work in some sort of build. Picked a cb because the following on them is huge, it helps that I also picked this up for $500
So here she is in all her glory
the kid who owned it didn't really know what he was doing.
He got pods and a mac 4 into 1. Then complained that the exhaust had a leak (there was more exhaust coming out of the head than the muffler). He assumed it was just needing gaskets so bought them but never installed them. I shrugged it off just thinking I'll take 30 or so mins to put them in.. I test rode it, ran well surprisingly but the exhaust leak was so loud I only rode it down the block and back.. loaded it up and before I left town went to a guy he refered me too who collects jap bikes and parts.
 Jason, the parts guys, turned out to have an entire pole barn full of anything and everything motorcycles. So I was looking for a cb750f tank to put on this bike but most were pretty rusty. Then I came along a cb500 twin tank (as seen on the ground in the picture above), I love the lines of it plus it is rust free, so I picked it up for $40 bucks. Will take a little tinkering to get it mounted on the 550 but I'll make it work.
Fast forward to today. Start taking the exhaust off and low and behold the kid put the exhaust collars on backwards.   :o
So I fixed those but now I'm getting a 3k rpm idle. My guess is he tuned it to run ok with the giant exhaust leak.. I took the carbs apart everything seems clean has a 100 main jets, which for pods and a 4 into 1 I don't know if those are big enough. Being new to carbs I sort of at a stand still until I do some research
Thanks for reading, hope to have this repaired so I can start the real building soon  :D
« Last Edit: June 17, 2014, 09:47:56 PM by adventure_prone »
Offline goldarrow
  • one day, i'll be an
Re: 1975 cb550 first build (project gaijin)
« Reply #1 on: June 18, 2014, 05:12:48 AM »
Welcome and nice looking bike.   That 3k rpm idle may just need to be brought down by the idle adjust screw
CB550 K0
Offline Damage Inc
« Reply #2 on: June 21, 2014, 11:01:42 PM »
G'day and all the best with your build.
Are you planning any other mods?
Being a welder in the Air Force , does this mean you do titanium welding?
There is nothing Man makes, that Man can't break.
« Reply #3 on: June 22, 2014, 04:29:27 AM »
Yep, titanium, colbalt, magnesium,  of course steel and aluminum.
He's where I'm at with it now.
the cb500T tank front is mounted the way I want it, need to weld a mounting tank to the rear of the tank and the frame still, then make a spacer to get the rear up higher, I want the bottom of the tank to be parallel to the ground. After that the tank, fender, and headlight bucket are being sand blasted. I'm going for a brushed look through out the bike, I think it'll look great.
Some other shots
This is with a 120 grit sandpaper, I think I'm going to go with something rougher still
I'm forever waiting on parts lol. I have the following ordered.
From cognito moto:
Triple tree top
Rearset brackets
Rearsets
Clip ons
Small battery
Electronics tray for under the seat
Headlight brackets
From dcc:
Tachometer
Cafe seat
Led tail light
Other randoms:
7 in Trucklite led headlight
New intake boats
Jet kit
Valve tappet covers
Still need to order a carb sync kit, but the couple places I've looked are sold out
Until the parts get here I'm stuck trimming of unused brackets trying to clean up the clutter on the frame.. trying to build this by the 4th of July to put it in the towns car and bike show, it's all Harleys here so it should stand out a bit :)
« Last Edit: June 23, 2014, 11:09:21 AM by adventure_prone »
« Reply #4 on: June 23, 2014, 01:54:33 PM »
Rolled it outside today, finished plastic blasting the tank so I popped it on to see if I'm want to leave it bare or paint it. I'm still undecided
« Reply #5 on: June 23, 2014, 02:10:47 PM »
I would at least sand it uniformly and clear coat it. Maybe that, a black pinstripe highlighting the countours and the original badges. Just my $0.02.
« Reply #6 on: June 23, 2014, 06:17:44 PM »
That's the plan. Was thinking of black on just the bents maybe, I'm sure I'll be changing it constantly
« Reply #7 on: June 25, 2014, 07:00:40 AM »
Got the bike up on jacks, wheels off, think I'm going to paint them silver or black.
Ordered a new chain and sprockets. Stayed with the 17 front but went to a 40 rear. We'll see how that goes.
Have parts coming in on Thursday and Saturday so hopefully I can start getting the bike buttoned up. It's getting pretty close to my deadline.
Took the exhaust off and started to wrap it. Forgot how filthy this stuff is haha
« Reply #8 on: July 02, 2014, 07:45:55 AM »
Wasn't happy with the way the rear end looked on the bike
so I decided to hack it off and start from scratch
« Reply #9 on: July 02, 2014, 07:51:16 AM »
Well that's adventurous. It looks like you've opted to mount the rear subframe at a higher than stock angle. What is your plan for the front and rear suspension?
Offline Tews19
  • I am no
« Reply #10 on: July 02, 2014, 08:49:39 AM »
Well said CB750. That is adventurous.  You seem to be moving pretty fast. Welcome to the site.
1970 Honda CB750 survivor.
« Reply #11 on: July 02, 2014, 08:53:27 AM »
The eyelet to eyelet is 1 1/4" taller, so I'll be running longer stocks, the front is going to stay stock for now. There's enough money into it as it sits.
« Reply #12 on: August 01, 2014, 03:20:09 PM »
Some much needed progress, I added some more scaffolding to distribute the suspension load a little bit more wasn't sure how I was gonna like the look, but it's growing in me
« Reply #13 on: August 02, 2014, 12:40:51 PM »
Bike is back on the ground!
« Reply #14 on: August 02, 2014, 05:15:07 PM »
My understanding i would be restoring the bike to stock rake. if I was to throw longer shock on a stock frame I would be changing the rake forward. But having changed the height of the frame in the rear ONLY, I would have to put on longer shocks to compensate back to stock rake
Technically I have the front lower by an inch so it should be pretty close to stock now? Just the bike all around is one inch lower
« Last Edit: August 02, 2014, 06:10:42 PM by adventure_prone »
« Reply #15 on: August 03, 2014, 07:19:27 PM »
Exhaust wrap is done
Offline Toustic
  • I can levitate birds... But nobody cares
« Reply #16 on: August 04, 2014, 08:32:33 AM »
I tried to go the exhaust-wrap route with the MAC 4-1 on my 550 but gave up. Cheap-stuff was too think, and I couldn't get it wrapped tight enough around the headers.
Your project looks good, I like the brushed metal look and the upswept seat loop.
Are you going for a raw-metal look on the tank? I like CB750 Cafe Racer Fan's suggestion for the tank. Raw but with a touch of "purposeful"  :)
Looking forward to see what follows.
"I totally take back all those times I didn’t want to nap when I was a kid."
« Reply #17 on: August 04, 2014, 03:48:50 PM »
Yes sir the tank is going to stay bare (for now). We'll see down the road, but I really just want to ride it so that's one less thing that'll need to be done
« Reply #18 on: August 07, 2014, 05:34:37 PM »
Been lazy
Noooooooooooo progress,  can't seem to find my bowl gaskets for the carbs
Offline Tews19
  • I am no
« Reply #19 on: August 07, 2014, 05:46:23 PM »
I had to order a new set 2 days ago due to not being able to find mine. 23 bucks!
« Reply #20 on: August 08, 2014, 05:23:09 PM »
Found them for $15 at the local moto shop.
Side note.
Anyone have an idea on how to fill this gap between the tank and seat. It's going to drive me crazy
think I might undo the leather up front and throw some extra foam in to fill it
« Last Edit: August 08, 2014, 06:43:14 PM by adventure_prone »
« Reply #21 on: August 17, 2014, 09:07:34 PM »
http://s1192.photobucket.com/user/ebowling325/media/VID_35741212_073611_zps140e1723.mp4.html
Got it started up. Went through the carbs to make sure everything was in good shape also jumped up to the correct jets. But now I'm having an issue with what I'm guess is the floats sticking, because fuel is pouring out of the overflow tube. Didn't have this issue before hand
« Reply #22 on: August 18, 2014, 03:22:38 AM »
Sticky floats is not uncommon after rebuilding. Debris that may have sat in your tank or carb bowls, or bad gas, gets lodged in. Try some simple remedies, while the bike is running, tap the body of the carb with a screwdriver handle. May dislodge the float and you're fine. Or, start the bike, then open the petcock, I find this to be preferred for my bike.
Thanks for that tips, I'll give them a try
« Reply #23 on: August 18, 2014, 08:31:05 PM »
Made my upper rear shock mounts today.
Before and after
In the shock
I'm going to weld on both sides of the plug then grind the back half somewhat flush. Made it long so I can get a good bead on it, I'm happy with the way they turned out. One less thing that needs to get done
« Last Edit: August 18, 2014, 08:35:23 PM by adventure_prone »
« Reply #24 on: August 19, 2014, 06:08:32 AM »
Thanks I think it should be good enough. I went with a 1/2-20 thread, just cause I had the hardware on hand
