Author Topic: 1975 cb550 first build (project gaijin)  (Read 7083 times)
Offline adventure_prone
Re: 1975 cb550 first build (project gaijin)
« Reply #25 on: August 19, 2014, 06:59:13 AM »
I'll let you re thread it when it gets to your place lol gotta trade me your '74 though
Offline Tews19
  • I am no
« Reply #26 on: August 19, 2014, 07:15:06 AM »
Made my upper rear shock mounts today.
Before and after
In the shock
I'm going to weld on both sides of the plug then grind the back half somewhat flush. Made it long so I can get a good bead on it, I'm happy with the way they turned out. One less thing that needs to get done
Some really nice work there. I'm sure you could sell those on the site. I'm curious how will you attach to the frame?
1970 Honda CB750 survivor.
« Reply #27 on: August 19, 2014, 08:21:15 AM »
I'd think, with no disrespect to Adv, that most members would require metric threads. Not all lathes will turn them, so I suspect thats exactly why ADV had to use SAE.
Metric wouldn't be an issue. Just limited on the number of metric dies I have to choose from.
1/2-20 is a very strong thread, just will confuse some folks if they attempt to replace the acorns with metrics.
Tews - simple enough to pass the slug end thru the frame mount, then weld from both sides (ADV, your plan?)
yes sir that's it exactly
Turning steel on lathes (or alloy for that matter) makes a really pretty part in my opinion.
« Last Edit: August 19, 2014, 08:29:01 AM by adventure_prone »
Offline 750mors
« Reply #28 on: August 19, 2014, 08:57:04 PM »
Coming along really nicely Adventure! Loving it!
« Reply #29 on: August 20, 2014, 01:31:21 PM »
Decided I wanted to do the gulf light blue and orange livery on the bike. So I do a Google search for paint codes and now I'm mad.
the frame on this bike is basically the same in the rear as mine
« Last Edit: August 20, 2014, 08:47:25 PM by adventure_prone »
« Reply #30 on: August 20, 2014, 08:50:23 PM »
Suspension slugs installed. Starting to get excited
need to find a wiring diagram so I can start cleaning up the stuff I don't need
« Last Edit: August 20, 2014, 08:53:31 PM by adventure_prone »
« Reply #31 on: August 21, 2014, 04:58:19 AM »
Here you go-
Are you planning to run a pipe beyond that header? Might have some tuning issues without some backpressure...
Thanks for the diagram.. I'm looking for one now, my buddy just replaced his stock muffler on on his bmw s1000rr, so I might find a way to slip that on. The issue I'm coming across is the cognito moto Rearsets are perfectly in the way to run exhaust up the side. It'll have a muffler on it before I ride it
« Reply #32 on: August 21, 2014, 05:20:54 AM »
The problem is the Mac header; it exits the the collector without redirecting the pipe to a muffler outboard of the frame. Differing years of 550s had different brake pedals for that reason. The MotoGP header and exhaust has a very subtle "S" from underneath to aide in clearing the frame for that reason. Still might have the occasionally conflict, unless you raise the rearsets too.
Might see if an exhaust shop can bend you up a small offset pipe and that has the transition from pipe to BMW slip-in welded on too. Could even bend it up a tad too if you prefer.
Or, since you weld, you can buy from here the components and cut and weld them to your hearts desire.
http://www.c5ignitions.com/exhaust-kits.html
Yup I hate this mac header. But I'll just make it work for now, I might be able to cut off the muffler of the back half of the mac and rotate it to get me a little closer to the area I want
« Reply #33 on: August 21, 2014, 09:27:46 PM »
Welded up the battery tray
I don't like the look of it at all. I think it kills the lines of the bike but I'm not sure what I can do about it, the electronics have to go somewhere sadly haha
question for people using electronic tray. What are you using/doing to make sure your stuff isn't hitting each other and shorting stuff out?
Side note, I was messing around with exhaust placement I'd love to do something like this but I just don't have the room to do it lol look awesome though!
« Last Edit: August 21, 2014, 09:29:17 PM by adventure_prone »
« Reply #34 on: August 22, 2014, 08:55:29 PM »
Redoing the electronics tray all together. I'm going to build a box that fills the entire upper triangle. Then splitting the box into to compartments upper half for electronics and lower half for storage
« Reply #35 on: August 26, 2014, 05:39:16 PM »
I hate wiring so much...
« Reply #36 on: August 26, 2014, 08:13:02 PM »
I found this which I think I'm going to start copying tomorrow
This SHOULD be the bare minimums to run
Offline Tews19
  • I am no
« Reply #37 on: August 27, 2014, 11:09:29 AM »
Cal that looks like a piece of art! I'm sure you could start producing that set up and members would start buying them. Is the moto part itself pricey?
« Reply #38 on: August 27, 2014, 12:33:43 PM »
Cal,
Have you figured out how to program the indicators to flash X number of times and then cancel?
I was also wondering about the following:  "the m-Button digitally processes signals and transmits them to the m-Unit V.2 over a thin cable." (from Motogadget)
I took this to mean that everything wired to the m-Button and then a single fiber optic/digital cable connected the m-Button to the m-Unit -- thereby eliminating all but a couple of wires to the m-Unit.  This would not appear to be the case.  Can you shed some light on this?
Thanks,
Don
« Reply #39 on: August 27, 2014, 05:57:41 PM »
No problem, I wouldn't mind a set like that myself but I can't justify the price, hell of alot cleaner but I don't know if it's worth that much too me
« Reply #40 on: August 29, 2014, 07:07:15 PM »
Little more progress. Figured the brake light out. For some reason dcc has the tail light set up as
Yellow=ground
Black=running light
Red=brake light
I was just assuming black would be ground lol
« Reply #41 on: August 29, 2014, 10:47:57 PM »
I know Hondas is green. But I expected an universal aftermarket tail light to be a normal ground color lol
Sadly today I noticed my steering is pretty notchy. I'd explain it as wanting to detent to center. So I think a taper bearing set up is in store for me
« Last Edit: August 30, 2014, 12:53:34 AM by adventure_prone »
« Reply #42 on: August 31, 2014, 11:12:33 PM »
Having alot of starting issues. Most of the time the bike won't electric start sometimes it'll kick start. Spark is intermittent. Wiring is a disaster. Bout to light it on fire
