Author Topic: 750 center stand  (Read 1436 times)
Offline jgary
    • Catholic Nature Cards
750 center stand
« on: May 23, 2005, 07:47:52 AM »
Hi.  I'm working on a bike that doesn't have a center stand.  Made installing new rear shocks a treat over the weekend.  I have a stand that I can put on it.  Do I have to tear the exhaust off (standard 4-4 pipes) or anything tricky like that to put the stand on?  Thanks!
John.
1972 CB 750
1976 CB 750
Offline Jonesy
  • Shop Rat
Re: 750 center stand
« Reply #1 on: May 23, 2005, 08:34:32 AM »
I can't remember if I had to take the pipes off or not, but I can tell you it's a real treat trying to get that huge spring on it! I think I got the spring on, got one side lined up, hammered the pivot pipe through and got the other side lined up with a line-up tool (steel rod with a gound taper on it). Good luck with it, as I fought with mine for a while....
Greg
« Reply #2 on: May 23, 2005, 08:53:18 AM »
you know, i had to take the exhaust off to put my stand on, but i think the bracket may have been bent.  the pivot pipe can only fit on from the right side though...i got the spring on pretty easy by pulling it back with a scredriver...good luck!
greg
Offline frostypuck
« Reply #3 on: May 23, 2005, 09:21:26 AM »
Someone once suggested placeing nickels in between the coils on the spring to strech it out, til you hook it up, then remove the nickels. Or currency of your choice. Beats having that hook slide off a screwdriver and come back at you.
Chris in Boston.
Boston, MA, USA
