Author Topic: Electric ignition Vs. Points  (Read 3662 times)
Javier
« on: September 21, 2006, 01:08:32 PM »
Is it worth buying and installing the electric ignition rather than keeping the points? Is it alot better, less maintenance, more dependable, worth the buy? What are the pro's and cons? Considering just for dependability, but have no first hand knowledge - thanks in advance.
Offline cmorgan47
  • smaller, lighter, quicker
    • theundergr0und
Re: Electric ignition Vs. Points
« Reply #1 on: September 21, 2006, 01:12:31 PM »
i kept points.
the maintenance isn't really that hard, they work just fine, and it's a lot easier to carry an extra set of points than an extra electronic ignition.
if i started racing, i might change my mind.
i love babies...
with a nice chianti sauce and a side of fava beans
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: September 21, 2006, 01:19:29 PM »
Ditto.
feeler guages, screw driver and a points file (striker strip from a book of matches in a pinch) are all ya need.
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #3 on: September 21, 2006, 01:22:06 PM »
I replaced my points with a Boyer Micro Digital electronic ignition.  I've been very happy with it.  Starts are easier, idle is smoother, and it's a set it once and forget it kind of thing.  Boyer even handles the advance digitally, so there's no dealing with possiblity of the mechanical advance sticking (not that this is common, I guess).
Dave
Offline Hockers Choppers
  • go away winter!!!
« Reply #4 on: September 21, 2006, 02:30:06 PM »
I just put in the dyna ignition and coils in my 78 cb750f. It was running fine and I had the points set and timed right. Just put in the dyna stuff to get a hotter spark. I can honestly say that I can not tell a difference! But the zero maintenence will be worth the money in the long run. Plus I plan on a big bore and cam this winter, then it might be more usefull.
The thing about common sense is that, it's not that common.
1978 CB750F SUPERSPORT 850cc, cam, porting, dyna ign, cr29's lotsa elbow grease and $$'s. Worth ever penny!!  (S0ld)
05 VTX1800F darkside
cb750 k1
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #5 on: September 21, 2006, 02:33:54 PM »
Us 650 riders are spoilt, of course, because the ignition on the bikes is already non-points. A PO changed to Boyer ignition on my Commando, and I admit I'm glad of that.
Bottom line: if it ain't broke, why fix it? Adjusting the points gets to be as second nature as doing the valves....... (and I don't have to do it any more, yay!)
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Online Bodi
« Reply #6 on: September 21, 2006, 03:43:00 PM »
Well, if you're carying a spare points set then your faith in them is rather weak.
I installed a martek iat least 20 years ago. For insurance I carried the points plate and cam - fairly doable substitution with the Martek - but never needed it. No problems in those 20+ years, easier starting and smoother running. I check the timing adjustment every year and it hasn't changed.
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: September 21, 2006, 03:57:24 PM »
I don't mind most types of regular maintenance on my bikes, but adjusting points and timing is not one of them.  As many miles as I put on my 750 each year, it's nice not to have to mess with them, ever.  I put the Dyna-s on over two years ago and haven't touched it since, and it starts easier and idles smoother.  I could think of a lot worse things to spend $125 on.
Offline jaknight
  • ....Round Town Ride......
« Reply #8 on: September 21, 2006, 04:02:53 PM »
     Well, this is how it is in my case.........
     I put a Dyna S on my '74 cb750 K4 about 3 years ago.  I haven't touched it since.
     It starts easier, runs better, and I believe my sweetheart gets better gas mileage........
     And, Ladies and Gentlemen, ;) ;), I can add nothing to that........
     ~ ~ ~ jaknight ~ ~ ~
"THE PEN IS MIGHTIER THAN THE SWORD........
..........EXCEPT IN A SWORD FIGHT"
"There is nothing new under the sun.........But there are many old things we do not know"
BIBLE ---> Basic Instructions Before Leaving Earth
Offline SohcCBs
  • 76 CB836F 77 GL1000
« Reply #9 on: September 21, 2006, 04:43:39 PM »
I put the DynaS in my '76 SuperSport when I bought it in 2000.  I actually had to adjust the timing (a tad) for the first time this year.
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« Reply #10 on: September 21, 2006, 04:53:28 PM »
all I will say is DYNA S DYNA S DYNA S HANDS DOWN  THERE MOTTO SET IT AND FORGET IT
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
« Reply #11 on: September 21, 2006, 05:11:13 PM »
Installed the older Dyna III sometime in the early to mid 80's and haven't changed a set of points since, haven't had to set dwell on a set of points since, haven't burned up any points since, haven't adjusted timing since. This part of the electricals has worked flawlessly. It hasn't had a miss-fire involving this area.
In my opinion this was probably the best money I've spent on my bike. If you're going to keep your bike - do it!
I'm not saying old school points are bad. I'm saying they are old school and more trouble.
Offline Jonesy
  • Shop Rat
« Reply #12 on: September 21, 2006, 07:30:29 PM »
Dyna S all the way.
Hotter spark. Easier starting. Set and forget. No gradually fading power due the spark retardation from worn breaker rubbing blocks. Nuff said!
Offline aptech77
« Reply #13 on: September 21, 2006, 07:51:58 PM »
Answer: YES, YES,YES and YES. NONE   ;D
« Reply #14 on: September 21, 2006, 09:59:53 PM »
Dave
We have the same as Dave on the CR750, thought it couldnt get any better untill a set of iridium plugs came from Mike Rieck.
The Bike now starts from cold and can be off choke in less than a minute, that's on open pipes and velocity stacks.
Runs clean as a whistle and is much more responsive.
Dont think twice, do it.
Sam.
Offline Raul CB750K1
« Reply #15 on: September 22, 2006, 12:44:41 AM »
My two cents is this: I have my CB750 as a classic bike, not a daily bike. It has been about 3.000 km now and no messing with points. The battery is almost flat because I use it once every other month, but it starts at the 8th or 10th kick -and I bet it has to do more with my unability to set the idle right at once, and the carb bowl filling-
I don't plan to upgrade to electronic. From my point of view, it would steal a little of the bike spirit. I may upgrade the master cylinder, but safety is something I'm more concerned with than performance or ease of maintenance. Adjusting a gap every 4k or 5k miles is not a big deal. What I may do this year, as I'm gonna have plenty of time, is tinker with thyristor or the like so the points trigger a solid state device that triggers the coil. I know, this is some kind of "electronic", but if it fails, you just have to bridge the thyristor and you are good to go.
Raul
Ibsen
« Reply #16 on: September 22, 2006, 01:52:46 AM »
Someone once wrote that the electronic ignition systems is the greatest  invention since the combustion engine itself.
And I belive he was right. Ask those guys with brit bikes and troublesome magnetos that have converted their bikes to an electronic ignition system.  ;)
It might take away some soul, but it do add easier starting,reliability, better performance and improved gas milage. The CB650 have got one as standard, so there is no option, but if it had a points ignition, I would have replaced it. I converted my Kawaski to a Boyer system 10 years ago, the system have worked flawless for 42 000 miles, and I have never looked back.
Offline nteek754
« Reply #17 on: September 22, 2006, 04:30:31 AM »
Hey all just another point no pun intended but you dont get any hotter spark with just the  points plate replaced need to add the coils for the hotter spark now  you wont get that  ponts bounce at higher rpms  with the dyna s but be carefull well in my case it will just keep climbing threw the power band and beyond  shift shift lol good luck  Craig in Maine  seven fifty four ever
