Author Topic: CB750 Turn signals  (Read 1765 times)
Offline kammery
CB750 Turn signals
« on: June 21, 2014, 09:56:28 AM »
 I own a 1975 CB750 . The Build date is August of 1974 . All four of my turn signals are the Flat round type . I suspect the ones that should be on this CB750 are the cone type . Any input or where I can look to determine this ? Where I live at I have not seen another CB750 any where . Thanks in advance .
Offline goldarrow
  • one day, i'll be an
Re: CB750 Turn signals
« Reply #1 on: June 21, 2014, 12:44:49 PM »
Post 75 bikes are the fat ones like Micky mouse ears
CB550 K0
Offline kammery
« Reply #2 on: June 21, 2014, 03:12:25 PM »
 Since it was built in August of 1974 then it should have the small lens turn signal . What month did Honda change to the large lens ?
Offline mrbreeze
  • Not your average
« Reply #3 on: June 21, 2014, 11:47:21 PM »
What side is your petcock on? Does the side stand have a rubber pad on the bottom. 75 has left petcock, rubber on sidestand, big turn sigs, and other differences. Whats the VIN & engine #'s? These will also tell you for sure. Your's is probably real close to the change date. Someone here said they change around Aug.-Sept.
MEMBER # 257
Offline mrbreeze
  • Not your average
« Reply #4 on: June 22, 2014, 12:09:52 AM »
MEMBER # 257
Offline kammery
« Reply #5 on: June 22, 2014, 09:13:38 AM »
 The Petcock is on the left side .It has a rubber strip on the kick stand . Looked on the web site you suggested . Looks like it should have the large turn signals .When I bought this last year , the owner  changed several things on it . His wife was selling it due to him passing away . She had no knowledge as to what was done to it . The picture in my screen name is the bike in question .
Offline goldarrow
« Reply #6 on: June 22, 2014, 09:25:54 AM »
That makes a 75 model and large blinkers are correct for the bike
CB550 K0
« Reply #7 on: June 22, 2014, 09:29:57 AM »
+1....Looks a Planet Blue K5.   Don't be surprised if some items are changed, the bike is nearly 40 years old.
