Author Topic: No Spark 1976 CB750  (Read 3904 times)
Offline ic455
  • 750 K6
    • My Gallery
No Spark 1976 CB750
« on: September 21, 2006, 03:49:55 PM »
Just got a non-running CB750 from a friend.  It used to run fine and I have ridden it.  He says that he went for a short ride, parked it; and it rained that night.  Next day bike won't run.  Electrical system is hacked to pieces, starter is inop, only kick will start it.  Has an aftermarket ign. switch.  I hooked bike up to battery to check wiring, have power at points (only when open) and power constant at black/white wires at the coils.  Still no spark when plug is inserted into wire and grounded (and bike is kicked over).  My thought is bad coils.  Any ideas?
Offline Bob Wessner
  • "Carbs Suck!"
Re: No Spark 1976 CB750
« Reply #1 on: September 21, 2006, 04:01:17 PM »
How long ago did it get wet? Could still be some water in there somewhere, particularly if it's a home brewed harness. You could try removing the covers, tank and open the headlight shell and get a fan going or park in the sun for several hours with the everything exposed. Maybe a long shot, but might be worth a try.
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: September 21, 2006, 04:03:59 PM »
Both coils rarely go off at the same time.  If you have power up to the coils, it's probably either the plug wires, the plugs, or possibly the condensers.
Offline ic455
  • 750 K6
    • My Gallery
« Reply #3 on: September 21, 2006, 04:12:50 PM »
Man, talk about quick response!!  It's been a couple months since it got wet, if it got wet, he said it rained but I don't know if the (torn) bike cover was on or not.  Headlight is the only functional electrical accessory.  I'll check out the condensers.  Thanx!
Offline SohcCBs
  • 76 CB836F 77 GL1000
« Reply #4 on: September 21, 2006, 04:40:17 PM »
If you want to keep this bike, I highly recommend you either get a new harness or rewire it from scratch.
Offline ic455
  • 750 K6
    • My Gallery
« Reply #5 on: September 21, 2006, 04:43:23 PM »
Yeah, that's what I've got planned for it in the future.  It's really not roadworthy but was being ridden anyway.  I plan to do some major restoration to this bike before I get serious about riding it.  Thanks!
Offline SohcCBs
« Reply #6 on: September 21, 2006, 04:48:20 PM »
When I first got mine, I spent about 30 minutes troubleshooting the electrical........and then stripped the bike of all wiring.  Then rewired it myself with all 12 guage wire.....10 gauge on the grounds.
Now, 6 years later, it's not as pretty (time to paint again), but it runs like a banshee.
« Last Edit: September 21, 2006, 05:00:57 PM by SohcCBs »
Offline ic455
  • 750 K6
    • My Gallery
« Reply #7 on: September 21, 2006, 05:11:25 PM »
That sounds like the best bet, this bike's wiring is a mess.  I'll get some pics of it on as soon as I find my digi cam.
Offline ic455
  • 750 K6
    • My Gallery
« Reply #8 on: September 21, 2006, 07:23:38 PM »
It lives!!  Looks like it was a bad connection at the coils.  I decided to double check all the wiring at the coils and found a loose butt connector.  I guess the coils were getting 12v sitting still but when I was kicking it the connector was breaking contact and causing a no-fire situation.  Now I just gotta get it to stop smoking!!
Offline SohcCBs
« Reply #9 on: September 21, 2006, 08:07:53 PM »
Congratts!!  That's persistance.  Sometimes it helps to walk away for a while, and come back later.
Offline ic455
  • 750 K6
    • My Gallery
« Reply #10 on: September 21, 2006, 08:58:15 PM »
Thanks!  A little break from a tough problem is always good, but even better when it includes some supper! ;D
Offline dusterdude
« Reply #11 on: September 22, 2006, 08:08:14 AM »
groovy
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
