Author Topic: check my cb450 timing!  (Read 2874 times)
Offline Carver
« on: June 23, 2014, 06:34:27 PM »
Head gasket blew out because a head nut kept coming loose even though i torqued to spec gunna use loctite this time.
Its a tiny tiny bit out but i think its an insignificant amount, what do you guys thing? also the exhaust mark is lined up perfect you just can't see it in the picture for some reason.
Cb 750 k3
Cb 450 dohc k4
fendersrule
Re: check my cb450 timing!
« Reply #1 on: June 23, 2014, 09:39:37 PM »
Looks good to me.
fendersrule
« Reply #2 on: June 24, 2014, 12:39:16 PM »
As long as the marks on the cam are somewhere within the "divot mark" on the head, even if some of it partially out, then it's my understanding that it's correct.
Whether or not you can get it closer is doubtful, but Bill lane would have the ultimate knowledge of this.
« Last Edit: June 24, 2014, 12:40:52 PM by fendersrule »
Offline tbpmusic
« Reply #3 on: June 26, 2014, 07:41:37 AM »
I'd run with it - you probably won't get it any closer than that.
Bill Lane
Offline faux fiddy
  • bike in a box
« Reply #4 on: June 26, 2014, 03:34:42 PM »
Seems to me that the stroke never wants to stay at tdc, and the mark may line up a bit different if you try to roll it backwards.
^^^^^^^/l^^^^^^^^^^^^^^/l^^^
Offline tbpmusic
« Reply #5 on: June 26, 2014, 04:25:46 PM »
That "run by" at TDC compression stroke is typical of 180 degree twins.
Turning backwards is to be discouraged at all times.........
Bill Lane
Offline Carver
« Reply #6 on: June 26, 2014, 06:21:37 PM »
if bill lane says its good enough, thats enough for me! the exhaust cam is the hardest because it wants to roll through the timing mark and the crank wants to roll past LT. I got worried because the last time I timed my bike before the head nut came loose and murdered my gasket I got it perfect dead on so I never got to learn how much leeway i have with the marks.
Cb 750 k3
Cb 450 dohc k4
Offline Bill/BentON Racing
    • BentON Racing
« Reply #7 on: June 27, 2014, 08:08:19 PM »
That looks fine, run it! K. Wish I was that far along with Chef Tuskey's. Bill
BentON Racing Website
BentON Racing Facebook
