Author Topic: cam stud replacement  (Read 406 times)
Offline wierzbarecording
« on: June 27, 2014, 09:08:56 PM »
Rebuilding my top end on my 72 cb750. I just started pulling up a can stud while torquing down.
What is the proper way to fix this? Should I replace them all? Just the one in question? Is it possibly because my torque wrench is out of spec?
Thanks in advance.
Kyle
Re: cam stud replacement
« Reply #1 on: June 27, 2014, 09:21:39 PM »
Pulling it out as in stripping the threads? It's only 6mm...
Needs to be done.correctly as it's open ended and is a source for leaks.....
« Reply #2 on: June 27, 2014, 09:36:58 PM »
Yes. Its not biting the threads anymore.
You can see its about 1 thread out in the picture.
« Reply #3 on: June 29, 2014, 08:49:30 PM »
So my plan right now is to get the stud out without destroying it, then helicoil the hole and reuse the stud. I was going to make sure there is plenty of thread sealer on the coil and stud.
Am I on the right track?
Nic
« Reply #4 on: June 29, 2014, 10:03:05 PM »
exactly
