Author Topic: I'm starting to find out why you shouldn't work on your bike stoned  (Read 3829 times)
Offline Scott
  • 72 CB750
Hi there
I picked up this CB750 K2ish a few weeks ago.
This bloke said he had gone through the bike and got it all sorted.
Including done up the front brakes and rebuilt the forks while putting in tappered steering head bearings
The bike wheeled freely enough and there was no evidence of fork oil leaks.
Thought I better go over the bike and take a closer look once I got it home
Front wheel when spun does about 1 revolution and then stops. Caliper seized and brake fluid leaks at all hose connections. One caliper bolt missing.
Wheel bearings the most noisy I have heard. Speedo cable screw nearly fallen out.
Oh well pull the caliper and wheel off. Better check the fork oil.
Left fork had two parts of stuff all oil and right side bone dry.
More to come I think
« Last Edit: June 29, 2014, 03:37:07 pm by Scott »
fendersrule
Re: I'm starting to find out why you shouldn't work on your bike stoned
« Reply #1 on: June 29, 2014, 03:37:37 pm »
Dang. Good call to check that stuff.
No matter who you buy it from (doesn't matter if they drink, or smoke ganja, or go to church) you should always do a 100% thorough inspection. I've always found "unsafe" items on all of my bikes no matter who the owner was/is.
BTW, when I work on my bike stoned (only sometimes, usually don't prefer it) I never miss anything, but I'm very tedious on everything that I don't get a whole lot done.  8)
Offline Scott
  • 72 CB750
« Reply #2 on: June 29, 2014, 04:41:30 pm »
Steering head bearings not replaced with tapered rollers.
No surprise here
Offline Trad
« Reply #3 on: June 29, 2014, 04:51:58 pm »
What a big liar. I hope you can still contact him and call him out on that bull#$%*. I work on my bike all the time on Ganga and my #$%* usually turns out better than when I'm stone sober. I tend to really go into the details.  :P
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline bjbuchanan
« Reply #4 on: June 29, 2014, 06:49:25 pm »
The guy was using all the buzzwords to make it a hot sale. Di(k move
Offline Scott
  • 72 CB750
« Reply #5 on: June 29, 2014, 08:12:29 pm »
I guess the piece of radiator hose above the fork ear can be used as an indicator as to the quality of tthis dudes work
« Reply #6 on: June 29, 2014, 09:06:43 pm »
"STONED" Have not heard that in awhile. Is that like being a little dizzy ??   :)
« Reply #7 on: June 29, 2014, 09:54:52 pm »
In racing it's called a nut and bolt check. I'd go over the entire machine. I had one like that once, it's nice now. Take your time.
Offline Scott
  • 72 CB750
« Reply #8 on: June 29, 2014, 10:00:44 pm »
I think this guy may have been a little too dizzy (is baked a term from Canada or USA).
He might just be full of sh#t and shouldn't be working on motorbikes
Offline Scott
  • 72 CB750
« Reply #9 on: June 29, 2014, 10:03:18 pm »
Hi Don
Yeah I'm not too worried how long it takes.  I have no time frame as to how long it should take.  Just ordering heaps of parts and do one little bit at a time.
Scott
« Reply #10 on: June 30, 2014, 12:59:58 am »
does he sell a few bikes scott?hes a bull#$%* artist #$%*ing dangerous liar!some young new rider keen for a bike could've gotten into an accident on that!
Offline Scott
  • 72 CB750
« Reply #11 on: June 30, 2014, 04:20:42 am »
mate not sure if he sells a few or not. He is about 3 hours from my place so I probably won't see him again
Offline greenjeans
  • 1972 CB750K2
« Reply #12 on: June 30, 2014, 12:36:02 pm »
If you do this long enough, you'll find that even though the seller promises that you could "ride it home or anywhere" , I still bring my truck and ramps.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #13 on: June 30, 2014, 01:28:57 pm »
No #$%*, unless I personally know the seller and the type of work they do I take whatever the average bozo seller says he did with a huge grain of salt. And check everything personally, my life depends on it.
Offline bjbuchanan
« Reply #14 on: June 30, 2014, 02:00:19 pm »
That statement right there means you DEFINITELY bring the truck and ramps lol
Offline Scott
  • 72 CB750
« Reply #15 on: June 30, 2014, 02:37:26 pm »
I pick all my bikes up in the trailer, never rode one home since I was a teenager.
I 100% agree with checking right over it or any bike for that matter, it's a must do.
Offline Scott
  • 72 CB750
« Reply #16 on: June 30, 2014, 02:48:36 pm »
Is this okay to use.
Maybe I can zip tie it to the fork tube.
Would blue tack work.
Should I phone the clown I bought the bike from and ask how he would"fix" it
« Reply #17 on: June 30, 2014, 03:03:48 pm »
Only if you intend to let the previous owner take it for a test ride! [when he's stoned]
Nic
« Reply #18 on: June 30, 2014, 03:22:53 pm »
When you get a new/used top tree don't forget to make up some .090" D washers or the same thing will happen again.
When I bought my #$%*box the engine was out of the frame, the guy said the top end had been rebuilt  but the engine had never run since, luckily ::)
The front chain slipper was missing along with the two outer Orings under the cam towers. One of the oil jets was broken, 90% of the 6mm threads in the head were stripped, one bolt was an imperial thread jammed in there. Pistons were old with gouges all over the tops of them, hone was very bodgy, old rings in there too, black goop oozing out from the head gasket. Cam chain had been replaced with a rivet link which was buckled. All the valves had been refaced so where they seat was now razor sharp. All sorts of bodgery too much to mention. Luckily the bottom end had not been apart. Top end had been rebuilt ;D
« Last Edit: June 30, 2014, 03:38:48 pm by Nic »
Offline Scott
  • 72 CB750
« Reply #19 on: June 30, 2014, 04:07:59 pm »
Hopefully mine isn't that bad.
He did put a crack in the sump though.
Turns out the oil leak isn't just because he didn't put a washer on the sump plug
Offline Scott
  • 72 CB750
« Reply #20 on: June 30, 2014, 04:10:14 pm »
He did leave me a spare o ring in the bottom of the sump.
Where do you reckon that is from
« Reply #21 on: June 30, 2014, 04:20:26 pm »
It looks to be either the one that seals the countershaft bearing (so oil can feed up into the mainshaft), which would be 2x6mm or 1.9x5.9mm, or else one of the oil seal O-rings from under the rocker towers? (Same size.) On most post-K1 bikes the top ones are 4 each of the 2x6 or 1.9x5.9mm size, but a precious few have one side smaller.
Offline Scott
  • 72 CB750
« Reply #22 on: June 30, 2014, 05:03:15 pm »
would it be best to pull the engine so I can get the valve cover off and have a look.
Thanks
Scott
Nic
« Reply #23 on: June 30, 2014, 06:33:28 pm »
Thanks
Scott
Those Orings can't just come loose n fall into the cases. If you haven't had the engine running and even more important, taken the bike out for a ride then you have no idea what you might need to do but I reckon what's happened with the Oring is that someone has been into the top end, lifted the cam tower/s up and one of the outer Orings has fallen down the cam chain tunnel because they had no idea what they were doing. Whether they replaced it or even knew it should be there is anyone's guess. Mine had the two outer ones missing.
If it was me I'd be rebuilding the whole engine and having a good look at all the tranny parts and replace the two needle rollers in the primary hub along with new chains n rollers etc. Do it right and then you know it's right. Or, start it up, ride it n see how you go, check that there is oil pressure to the top end before you ride it, take out #s 1n4 exhaust tapet plugs n see if you can see oil once you get it going.
« Reply #24 on: June 30, 2014, 11:32:25 pm »
got his email address scott?send him all those photos with THANKS #$%*!
