I don't think it as big as a deal as scott and mcr make it out to be. Certainly not a few millimeters. As long as your front and back wheels are in the same plane, I think that is the important thing. If you look at the rear end of the 77-78K there is nothing symmetrical or centered about it. The shock mounts are biased and if I remember correctly, the wheel isn't perfectly centered in the swingarm either.
If you have any more issues with the steering, AllBalz sells a tapered steering bearing set that is really nice and not a lot of money. Some guys have reported that the removal of the old races has been difficult but I just did it on a '76k that I am working on and it wasn't too bad. Bearings like to come out and go in perfectly square to the recess. Once they get cocked off a bit, that's when problems arise. Keep that in mind, and with a little patience any bearing can be replaced without a fancy hydraulic press. There are several threads on this forum that address the AllBalz installation. I've learned that a Mapp torch and a freezer are two of the best tools when fixing up one of these bikes.
Cheers
