Author Topic: Domino quick turn throttle  (Read 1336 times)
Offline 123mclaren
« on: July 01, 2014, 09:07:54 AM »
Anyone have any experience with the domino xm2 throttles
http://www.domino-group.com/en/catalogue/throttleControls_Detail.aspx?idmaster=4329
Would like to get it to work with my 400f. Only problem is cables. Not sure of the so called "universal" cable kit will work.
Offline lrutt
Re: Domino quick turn throttle
« Reply #1 on: July 01, 2014, 10:13:51 AM »
quick turn throttles are kind of a #$%* for real world riding. Racing ok,
Offline calj737
  • I refuse...
« Reply #2 on: July 01, 2014, 10:33:10 AM »
I have them for 3 bikes, 2 of which are the XM2. Universal cables worked fine for me, but you need the correct version of the cable is all. You could also measure your current cables and find a model (currently supported) that had the same length and order them. As long as the throttle linkage mounts to carbs, you'd be fine.
Best part of this unit is the different cams, so I find them preferable to the stock, and for the street.
Offline 123mclaren
« Reply #3 on: July 01, 2014, 01:43:17 PM »
Thanks cal. So you went with the domino universal or a motion pro,etc?
Offline 123mclaren
« Reply #4 on: July 01, 2014, 01:43:57 PM »
Don't think any of the new ones would work as most new bikes hook up under the tank and are quite short
Offline calj737
  • I refuse...
« Reply #5 on: July 01, 2014, 01:45:06 PM »
Domino. Bought them through Revival Cycles. Universal cable kit was $95 but love the product.
« Reply #6 on: July 01, 2014, 01:51:22 PM »
Quick turn throttles and mechanical slide carbs without accelerator pumps?  Seems like a recipe for frequent engine stumble.
Fine for CV carbs and fuel injection, I expect.
Offline calj737
  • I refuse...
« Reply #7 on: July 01, 2014, 02:06:46 PM »
You're right if you use the most aggressive ratio, TT. I've had no adverse reaction to using either their "slow" or "mid" cam. Mostly, it's how hard you turn it, like the standard throttle, as to how quick it opens.  My experience has been that it allows you turn less, to achieve more opening, so for clip-on bars, it's nice for wrist action.
Offline 123mclaren
« Reply #8 on: July 01, 2014, 03:49:06 PM »
Didnt want to have to re-grip for full throttle. Also the grip and throttle were free. Thanks again cal.
