Author Topic: What is it? ...Electrical  (Read 1599 times)
Tiek101
« on: September 22, 2006, 12:16:15 PM »
Since I don't have a donor bike and I'm building from a basket, can someone tell me what this is and where it goes?
...thanks -Keith  ...Click it for biggun--->
supersport_CB400F
Re: What is it? ...Electrical
« Reply #1 on: September 22, 2006, 12:26:15 PM »
Yellow wires on my bike go from the gen to the rectifier, if your bike is a Honda maybe that’s a starting point, you never mention what your basket of bits is  ;D
Tiek101
« Reply #2 on: September 22, 2006, 12:43:35 PM »
Oh yea...  It's a CB750K5  ...sorry 'bout that.
Offline Rushoid
  • Shameless
« Reply #3 on: September 22, 2006, 01:45:30 PM »
Yup, it's the rectifier. Should go behind the left cover by the fuse box, regulator, etc. Don't remember the wire connections off the top of my head but if you have a manual, it's in there.
Go Cards!! Go Colts!! Go Bucks!!
SOHC/4 Member #3452
supersport_CB400F
« Reply #4 on: September 22, 2006, 03:10:06 PM »
Thats what I thought, but I dont have one of those bikes........good they use common colour codes  ;D now if only I could find the size of tube I'm looking for I'd also be happy ;)
Offline Jonesy
  • Shop Rat
« Reply #5 on: September 22, 2006, 08:05:15 PM »
All the yellow wires go to the alternator- doesn't matter which one goes to which.
The Red goes to the positive battery terminal and the green goes to the ground. If the bike you're putting it on has the original wire harness, it should plug right in. The only difference between the early and later silicon diode rectifiers was the tang on the connector to keep it from vibrating apart:
« Last Edit: September 22, 2006, 08:09:13 PM by Jonesy »
