Author Topic: goodwill outlet store find. (Rotel)  (Read 998 times)
Offline 78 k550
« on: July 02, 2014, 05:20:32 PM »
Hey All,
Just scored a Rotel RB956AX amp and a RC980BX pre amp and a Yamaha tuner TX-540
All for 18.00
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: goodwill outlet store find. (Rotel)
« Reply #1 on: July 02, 2014, 05:38:02 PM »
Sweet, Rotel made good equipment back in the day.
And we need pictures of course or else it never happened.
Offline 78 k550
« Reply #2 on: July 02, 2014, 05:53:57 PM »
ok, here is one.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #3 on: July 03, 2014, 07:28:06 AM »
Noice.
You need to get one of those brute matching two channel amplifiers to really rock the house.
What speakers do you plan on rocking with those?
Offline mark
« Reply #4 on: July 03, 2014, 09:17:14 AM »
dammit I'm getting sick of hearing about all the great effing deals at the Good Swill Outlet Store.
All they have here is retail stores where everything is priced like they're proud of it.
Dammit gimme an Outlet Store already.
Aargh.
/rant
F you mark...... F you.
Offline 78 k550
« Reply #5 on: July 03, 2014, 01:46:46 PM »
Noice.
I made some in 86 like Klipsch 12 pyle driver with mid horn and horn tweets. I run a NAD 2200 now only a 2 channel amp and can also be a mono block.
I picked up some bookshelf B&W's years ago I might be dusting them off.
Starting to look like a great garage/workshop system.
Paul
« Last Edit: July 03, 2014, 04:14:10 PM by 78 k550 »
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #6 on: July 05, 2014, 01:55:41 AM »
I pulled a pioneer A-109 the other day from a dumster that works fine,i still have the sanyo DCA-411 I bought new in about 1980,works great.
Offline 78 k550
« Reply #7 on: July 05, 2014, 05:45:24 AM »
Nice find Dave. The older stuff is cool to have.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline grcamna2
« Reply #8 on: July 05, 2014, 06:25:33 AM »
I have never bought a 'new and improved' anything ! I like the older good quality things that're made to Last and I DON'T believe in making everything that's 'older than 10-15 years' obsolete !  >:(  ;)
« Reply #9 on: July 05, 2014, 03:17:19 PM »
I still use the speakers and turntable I bought with that dca 411,all sounds great,replaced the belt and needles of course over time,the volume pot sounds a bit scratchy when its turned through the speakers.
Offline 78 k550
« Reply #10 on: July 05, 2014, 03:32:55 PM »
can some electrixcal contact cleaner fix it from scratching?
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
« Reply #11 on: July 05, 2014, 05:16:43 PM »
yeah I think thatll solve it,do them all and blow out dust etc maybe?you know the saying though leave well enough alone?
Offline mark
« Reply #12 on: July 06, 2014, 10:08:37 AM »
Paul
The shop sounds come from a Sherwood receiver that I got at a yard sale ages ago. There was a piece of toothpick that had to be stuck in the Muting switch just so or you got no FM. Volume and balance pots extra scratchy and right channel would drop out unless the knobs were set just so....
Found a tiny can of DEOXIT and gave all the controls a squirt. Worked the buttons and knobs some and another squirt.
Let stuff dry for a few and hooked back up....
No more scratchy. No right speaker dropping out. NO MORE TOOTHPICK!
(the stuff works)
« Reply #13 on: July 06, 2014, 10:13:54 AM »
For balance and volume controls you would be better off using a product called faderlube that does not wash out the protecting lube they put on those controls. Deoxit clears all that stuff out and takes away the original feel and can screw them up sometimes.
Offline grcamna2
« Reply #14 on: July 06, 2014, 10:28:23 AM »
Paul
if they're a little scratchy then spray just a tiny amount of de-oxit into there and that'll clean it up, w/ a lot of knob-turning to get it nice.  ;)
Offline mark
« Reply #15 on: July 06, 2014, 02:16:23 PM »
If I had a big can then we'd be in trouble.
As the Deoxit can was the 7 gram size, and I had to divvy it up between a whole mess of knobs and buttons, i wasn't going to squirt enough to wash out anything.
It seems to have softened the 40 year old grease in the switches as they don't feel as crunchy as they did and thankfully no more bits of broken toothpick to hold the switch just so.
If I screwed something up then I'm out a $10 yard sale brick. oops.
I'll keep that in mind next time around though.
Offline grcamna2
« Reply #16 on: July 06, 2014, 07:11:38 PM »
Hey Dukie, Faderlube? is it available locally or only online ? I know what you mean about washing out the original factory special lube they put into the rotary knobs,I like that original 'feel' also.
« Reply #17 on: July 07, 2014, 11:23:51 AM »
It is made by the company that makes deoxit. Probably easiest to get it online.
