Author Topic: how to remove grab rail? 750k 78  (Read 601 times)
Offline nixon
« on: July 03, 2014, 01:15:40 AM »
well Im puzzled!
Is their a technique or trick to remove the 2 side bolts ? it seems they are locked in the collars in between the guard and the grab bar?
Do you remove the rail with bolts still in collars and squeeze /scratch guard?
Bolt rotates easy and free from guard..but ive tried wedging it out it just not happening
« Last Edit: July 03, 2014, 01:26:34 AM by nixon »
cb750a 77, cbr900rr 93 with auto clutch
Riding tip " turn in late, feeling great.  Turn in early,  feeling squirrely "
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: how to remove grab rail? 750k 78
« Reply #1 on: July 03, 2014, 04:17:03 AM »
Looks like the threaded end of the bolt is bent. The bolts are still available from Honda. I would rotate the bolt to verify whether it's bent or not (watch the threaded end of the bolt for eccentric movement). The "collar" portion is not much bigger than the bolt, so even slightly bent would be difficult to remove. If it is bent, you might be able to hacksaw the threaded end off, or remove the fender, hacksaw the head of the bolt off and remove the bolt from the inside.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline nixon
« Reply #2 on: July 03, 2014, 06:52:48 AM »
thanks, thought i might have missed something simple..pretty sure your right.
