Author Topic: Best Triple Tree for Seeley  (Read 6077 times)
Offline Humble Pie
  • Seeley #519
« on: July 03, 2014, 07:01:34 AM »
I got a tree with this thing but its kinda funky ( lil tweaks here and there ) I have been reading there are a few different rake CB750 trees, which one will give the best steering with the Seeley 28 degree rake ?
Here is all the parts for the dual disc front end, that came with the bike, it was sitting for 30 years the guy said so guessing that kind of dates the parts.
Also are the two threaded posts on the neck for fairing mount ?
« Last Edit: July 03, 2014, 08:34:06 AM by Humble Pie »
Offline turboguzzi
Re: Best Triple Tree for Seeley
« Reply #1 on: July 03, 2014, 10:11:37 AM »
you should be aiming to about 4" trail
enter your data here changing offsets till you get the right trail,
enter 0 & 0 in the last two boxes (they are for harley double offset triples only)
https://www.rbracing-rsr.com/rakeandtrail.html
Offline Humble Pie
  • Seeley #519
« Reply #2 on: July 04, 2014, 07:53:39 AM »
Also what do I need as far as master cylinder ? It has dual stock calipers
Offline Tim2005
« Reply #3 on: July 04, 2014, 10:29:40 AM »
If you are going with stock forks and wheel (which I bet you will regret as soon as you ride it) then stock triples too, you can't get any triples for 35mm forks with more offset and you wouldn't want less offset.
m/cyl- AP are best, GSXR750 work well with clip-ons, lots of options, depends on fairing choice & clearance too. Radial are really good performers but look too modern imho.
« Reply #4 on: July 04, 2014, 04:53:51 PM »
Less offset is better than more offset Tim, a common misconception, most people get it wrong, less offset will give MORE trail and considering the trail on a 750 is around 3.75 inches stock, a little less offset adds some trail which aids stability, as Turboguzzi said, trail around 4 inches is a good compromise of stability and handling, more offset would be dangerous if not catastrophic.... :o {most, if not all modern sports bikes have around 4 inches of trail}2 of my 3 750 honda's will have slightly less offset on the triple clamps {slightly more trail}, the 3rd is stock {60mm}, still with custom clamps to suit the 41mm forks i'm using...... ;) The F model 750's had less offset {10mm i think from memory?} and slightly different rake and were known to be more stable than the K's..... ;)
« Reply #5 on: July 04, 2014, 08:11:07 PM »
The early K triples had 60mm offset , and the K7/K8 had 50mm offset. I don't know #$%* about F models. ::) In any case, Mr Seeley designed the 750 frame around the original bike, (unlike the Rickman) so the "best triple tree" for a Seeley would probably be a CB unit, at least from a geometry standpoint.
Offline Tim2005
« Reply #6 on: July 05, 2014, 03:10:29 AM »
I was of course aware that less offset gives more trail. Having experience of trying different triples on a Seeley, you do not need more trail, less trail improves the turning and stability is still rock solid.
Offline Humble Pie
  • Seeley #519
« Reply #7 on: July 05, 2014, 04:59:44 AM »
Perfect, thank you all
« Reply #8 on: July 05, 2014, 05:45:08 AM »
 Ceriani trees, the roadrace type,  may give greater offset, have to check the measurement on mine..
Offline Humble Pie
  • Seeley #519
« Reply #9 on: July 05, 2014, 06:27:48 AM »
From the look of the parts seems the original owner was going for a CR750 type front end
« Reply #10 on: July 05, 2014, 04:18:28 PM »
That depends on what the numbers are Tim, I was correcting that for the OP as you DO NOT want to have less trail if the bike he has, has stock Honda clamps, as i said, that would be dangerous and tank slappers and instability would be the result of the low trail numbers..
What rake does the Seeley frame have and whats the stock Seeley offset..?
Offline Humble Pie
  • Seeley #519
« Reply #11 on: July 05, 2014, 04:35:02 PM »
28 degree rake
56.6in wheelbase, 30in seat height. Engine lower by O.5in, seat by 2in than original Honda. Ground clearance 6in, castor angle 62 deg, trail 9 in. Turning cycle 18ft 10in.
« Reply #12 on: July 05, 2014, 05:54:42 PM »
28 degree rake
Trail can't be 9 inches, it would handle like a long chopper if that was the case, great in a straight line but you'd have to talk it into going round corners... ;D, I think you'll find its around 4 inches... If you can give me the triple clamp offset i can calculate the trail... ;)
« Reply #13 on: July 05, 2014, 07:11:00 PM »
Since the stock Honda trees available in '75 had 60mm offset, that's the number I would use, Mick.
« Reply #14 on: July 06, 2014, 01:49:04 AM »
Yeah, somewhere around there Scott, the rake is very similar to the old Honda's as well, 60mm would do fine... ;)  If thats the case there are plenty of people making clamps for the stock sized forks... ;)
Offline Humble Pie
  • Seeley #519
« Reply #15 on: July 06, 2014, 05:18:32 AM »
Cool thanks and here is where I got the trail info from
http://www.seeley-honda.com/tech.data.htm
« Reply #16 on: July 06, 2014, 06:24:34 PM »
That may be a typo? Perhaps it is 9 cm, or 3.543"?
« Reply #17 on: July 06, 2014, 07:56:53 PM »
thats possible but i just calculated that if you have 325mm to the centre of the front wheel spindle {got that measurement from a 19 inch tire shod wheel in my garage}, with 28 degree headstock angle and 60mm of offset, the trail would be around 104.8mm {4 and 1/8th inches}. if you drop down to an 18 inch front wheel its 91.5mm of trail {3.6 inches}, if using an 18 inch front i would use a 50mm triple clamp offset to give 102.8mm of trail {4and 3/64 inches}... ;)
Offline 01Thomas
« Reply #18 on: July 09, 2014, 01:31:21 PM »
I run my Seeley with stock trees and stock wheels, with modified stock forks (changed the spring rate) and Konis in the rear. I also have a dual disc set-up and I use the stock master cylinder (with a small mod). I have several bikes, younger and older, faster and slower than the Seeley and for me it handles nicely. We don't know in which direction you want to take your Seeley (figuratively speaking) but my recommendation is to stay with the stock tripple-trees.
As someone else here said, Colin Seeley designed his frame to work best with stock Honda components - in the 1970s.
1971 Honda CB750 Four K1 [Engine: CB750E-1113521 / Frame: CB750-1113838]
1977 Seeley Honda CB750F (F1) [Engine: CB750E-2551214 / Frame No: SH7-655F]
'96 Yamaha YZF750SP & '81 Moto Guzzi SP1000 & '80 Moto Guzzi 850 LeMans II & '82 Bimota KB-3 [Frame No 49] & '66 Ducati 50 SL/1 & '53 Miele K-50 & '38 Miele 98
« Reply #19 on: July 09, 2014, 04:26:39 PM »
Whilst i understand what you are saying,  I also know that suspensions and understanding of suspension geometry has come along way since then and if you know what you are doing you can always improve on what was done way back then, If Colin Seeley was to build that frame today he would definitely use different geometry...... ;)
« Last Edit: July 09, 2014, 06:35:24 PM by Retro Rocket »
« Reply #20 on: July 09, 2014, 06:29:24 PM »
Thomas, were there any geometry changes, ie rake, for the F Seeley frames, or just oil tank mounting tabs? What about the racing frames?
« Reply #21 on: July 09, 2014, 06:36:41 PM »
Thats a good question Scott, as the F model Honda's had different geometry.... ;)
Offline Humble Pie
  • Seeley #519
« Reply #22 on: July 09, 2014, 07:12:54 PM »
yes ,,and ??????
« Reply #23 on: July 10, 2014, 03:26:22 AM »
yes ,,and ??????
Slightly different rake and 10mm less offset on the triple clamps.
75/6 F  wheelbase 57.9 inches
            caster angle  28 degrees
            offset 50mm
            trail  4.5 inches
76K     wheelbase 57.3 inches
           caster angle 27 degrees
           offset 60mm
           trail  3.7 inches
Offline Humble Pie
  • Seeley #519
« Reply #24 on: July 10, 2014, 05:33:56 AM »
yes ,,and ??????
            offset 50mm
            trail  4.5 inches
           offset 60mm
           trail  3.7 inches
Awesome, thank you
