Author Topic: 750 F2 and K4 head swap  (Read 408 times)
Offline Dion
« on: July 06, 2014, 11:44:47 AM »
Hi Guys, Busy rebuilding a sohc F2.  The bottom end is great, however the head is stuffed. Needs a cam, valves, guides, etc. The cost of importing parts to SA is astronomical. I have a good 750 k4 head, barrel  and pistons. I know that the F2 and pre models differ in these areas. However is it possible to swap out the top end as a unit ???? Thanks
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: 750 F2 and K4 head swap
« Reply #1 on: July 06, 2014, 11:52:58 AM »
Yes. As long as you're using the cylinders to match the early head you will be in good shape. You are actually better off since stuff like piston rings and even pistons are easier to get for the earlier K models. The only possible issue might be the carb boots (between the carbs and the head). Measure the size of the connections to the head to see if they are the same, or whether you need to use the early carbs (and boots) to match the early head.
There may be others that know more about the carb boots that can chime in...
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
