Author Topic: 79' 650 Cam removal  (Read 1064 times)
Offline redrider736
79' 650 Cam removal
« on: July 08, 2014, 01:42:30 PM »
Purchased  a 79' CB 650 motor for the Oil pan and Cam to put into my 78' CB  550...... I have never removed or opened up a motor until today... Got  the motor out of the frame easy enough,  but not sure how too remove Cam?
78' CB550k (Not Run'n / Basket Case Project)
77/78 cool 2 member #269
Offline calj737
  • I refuse...
Re: 79' 650 Cam removal
« Reply #1 on: July 08, 2014, 01:47:10 PM »
Remove tappet covers, release all tension of rockers, remove rocker cover.
Locate cam sprocket. Screws on either edge need to removed, chain slipped off. You need to release tension from cam chain tensioner to create "slack" in the chain first (below carbs, nut on engine). Once chain is slacked, slip chain off, but tie it off from falling into engine. You may need to rotate crank to get to both bolts on sprocket.
Offline goldarrow
  • one day, i'll be an
« Reply #2 on: July 08, 2014, 01:59:06 PM »
If this is good motor, drop it right into the 550 frame???
CB550 K0
Offline redrider736
« Reply #3 on: July 08, 2014, 02:08:13 PM »
Thanks calj737, just wasn't sure how to get "slack" on the chain..........
« Last Edit: July 08, 2014, 02:16:24 PM by redrider736 »
Offline redrider736
« Reply #4 on: July 08, 2014, 02:11:29 PM »
Don't know when it ran last or really any history from the PO... It didn't come with carbs or exhaust...
« Last Edit: July 08, 2014, 02:14:30 PM by redrider736 »
Offline Bankerdanny
  • Endeavor to persevere
« Reply #5 on: July 08, 2014, 02:18:44 PM »
If all you want is the cam, then you can cut the chain off with a cutting wheel, just take care to cut where the chain is not touching the sprocket so you don't damage it.
Offline redrider736
« Reply #6 on: July 08, 2014, 02:19:58 PM »
My have made a error on the tear down........  You mentioned  "release  all tension of rockers" prior  to removal of the rocker cover...  I didn't do that,  is that a concern?
Offline calj737
  • I refuse...
« Reply #7 on: July 08, 2014, 02:22:27 PM »
It can be. On the 550/500 you need to do this to avoid damaging a valve that may be under compression at the moment. Not sure if the 650 rocker cover is the same in this respect. If you pulled it without hearing or feeling something "ugly" you're probably okay.
Offline redrider736
« Reply #8 on: July 08, 2014, 02:29:41 PM »
Covers were barley on.....  For next time how do I release tension  ?
Offline Bankerdanny
« Reply #9 on: July 08, 2014, 02:33:51 PM »
you loosen the screw adjusters. A 10MM (I think) wrench loosens the lock nuts, then a flat bladed screw driver to back the adjusters out will remove the tension. You can test first to see if you can move the rockers with your fingers, the ones you cannot you loosen manually.
Offline calj737
  • I refuse...
« Reply #10 on: July 08, 2014, 02:35:51 PM »
Remove the tappet cover for each cylinder, both intake and exhaust. Look inside, and insert a blade screwdriver into the adjuster, but then use a 10mm box to loosen the adjuster all the way. This is the same technique for adjusting valves, only instead of tightening/loosening to a feeler gauge, you're taking all tension of the rocker and spring.
Offline cb650
« Reply #11 on: July 08, 2014, 02:48:21 PM »
What are you going to do with the rest of the motor?  I might be interested in a couple items.
Offline redrider736
« Reply #12 on: July 08, 2014, 02:54:17 PM »
I am planning to use the Cam and oil pan,  but everything  else  is up for grabs..
Offline redrider736
« Reply #13 on: July 08, 2014, 03:01:45 PM »
Not sure what I am doing wrong but I can't seem to get any slack onto the Cam chain?
Offline redrider736
« Reply #14 on: July 08, 2014, 03:09:51 PM »
Both Cam chain tension bolts are loose
Offline calj737
  • I refuse...
« Reply #15 on: July 08, 2014, 03:42:27 PM »
Remove the left side, front cover (stator) and put a large socket on it, I believe 14mm. Rotate the crank a bit. The chain won't be super loose. You will also need to remove the 2 bolts on the sprocket mid way along the cam. That will allow you to slip the chain off the sprocket, sort of work it off and over to free the chain. Takes a bit of fiddling, but it will come free.
If nothing seems to work, take a Dremel or small cut-off tool and cut the cam chain, not near the sprocket or cam itself. Protect the debris from falling into the engine interior, and then remove the entire cam chain from the engine.
Offline redrider736
« Reply #16 on: July 08, 2014, 04:31:27 PM »
Thanks calj737! Success
Offline redrider736
« Reply #17 on: July 08, 2014, 04:38:33 PM »
Thanks Bankerdanny,  I should have looked here first before "tearing" into her!
Offline calj737
  • I refuse...
« Reply #18 on: July 08, 2014, 04:39:19 PM »
It had to be simple, if a simple-minded dolt like me could think of it  ;)
Offline MiGhost
  • What was that about being an
« Reply #19 on: July 08, 2014, 04:40:56 PM »
Make sure you keep the tach drive gear. You will need it.
The 500/550 tach drive gear is not compatible with the 650 cam.
You will also need a 650 tach.
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
Offline redrider736
« Reply #20 on: July 08, 2014, 05:00:22 PM »
Thanks ghost! Going to have to source a 650 Tach, the bike was missing it and a bunch of odds & ends
Offline goldarrow
« Reply #21 on: July 08, 2014, 05:28:58 PM »
Just cap the valves cover if you don't want to run tach
CB550 K0
Offline cb650
« Reply #22 on: July 09, 2014, 06:07:08 AM »
I'll trade u a tach for the starter cover and outer rocker covers.  if they are original 79.
