Support the site. Your contributions keep this site running.
I guess you are missing the linkage on the Tripple ? ( under / behind the headlight )There should be a piece where the 2 eyes get mounted in with banjo's, and where the pressure switch to activate your brake light is in.http://www.cmsnl.com/honda-cb750k6-four-general-export-dkdm_model14382/partslist/F05.html#resultsItem 4 on this drawing.
Quote from: Tetter on July 10, 2014, 03:17:16 AMI guess you are missing the linkage on the Tripple ? ( under / behind the headlight )There should be a piece where the 2 eyes get mounted in with banjo's, and where the pressure switch to activate your brake light is in.http://www.cmsnl.com/honda-cb750k6-four-general-export-dkdm_model14382/partslist/F05.html#resultsItem 4 on this drawing.Is that a standard part that originally came on the bike? My bike is a '78 K8... it had a brake line go from the Master Cylinder directly to the caliper with no linkage in the triple.
Quote from: Prez1967 on July 10, 2014, 04:08:21 AMQuote from: Tetter on July 10, 2014, 03:17:16 AMI guess you are missing the linkage on the Tripple ? ( under / behind the headlight )There should be a piece where the 2 eyes get mounted in with banjo's, and where the pressure switch to activate your brake light is in.http://www.cmsnl.com/honda-cb750k6-four-general-export-dkdm_model14382/partslist/F05.html#resultsItem 4 on this drawing.Is that a standard part that originally came on the bike? My bike is a '78 K8... it had a brake line go from the Master Cylinder directly to the caliper with no linkage in the triple. I'm not sure for a K8 ( it was never in the Netherlands ) but my Nephews K7 has one still..... Do you have a sensor or switch for the brake light somewhere else ? EDIT: yes you have. 1 line on the USA K8, and item 1 is a switch in the master.http://www.cmsnl.com/honda-cb750k8-four-usa_model14397/partslist/F05-1.html#resultsThe set you bought is using the linkage, in other words, you got the wrong set.....You just need 1 line
