Author Topic: Oh No! Am I screwed!  (Read 2779 times)
Offline jamesv220820
« on: July 11, 2014, 10:06:31 AM »
I started installing my forks today and went by the book which said to tighten the top and lower bridge bolts 13-17 ft lbs and this happened!
WHAT DO I DO!!!
There is nothing to fear but fear itself . . . and trying to restore a cb350f
Re: Oh No! Am I screwed!
« Reply #1 on: July 11, 2014, 10:14:53 AM »
Bummer  :-\
time to look for another lower tree and stem
(the 350F does not require a spacer at the clamp)
« Last Edit: July 11, 2014, 12:48:12 PM by flybox1 »
« Reply #2 on: July 11, 2014, 10:16:07 AM »
CMSNL does have new ones
« Reply #3 on: July 11, 2014, 10:19:37 AM »
Bummer  :-\
(the 350F does not require a spacer at the lower clamp)
its the top bridge the lower one is still ok
« Reply #4 on: July 11, 2014, 10:29:14 AM »
The Crack goes all the way through on the front.  half way down in the inside.  it doesn't completely go through on the bottom.  You wonder why this bike has taken me 5+ years and $4k to restore .  screw this this bike is soon to be parted out if stuff like this keeps happening
« Reply #5 on: July 11, 2014, 10:41:34 AM »
Sorry James.  saw lower bridge bolts in your OP and thoght thats what it was.
Take a break, no pun intended, and get to something else.
maybe someone here is parting one out and can help.
« Reply #6 on: July 11, 2014, 10:50:17 AM »
Don't freak.  That is not a rare part.  What bike and year?  I probably have one for you.  Did you have the D washers in there?
Offline Deltarider
« Reply #7 on: July 11, 2014, 11:14:47 AM »
Feel sorry for you. Could you have made an error setting the torque wrench?
BTW, I am not particularly fond of using these wrenches for low torque values.
CB500K2-ED Excel black
« Reply #8 on: July 11, 2014, 11:33:24 AM »
D washers?
It is a 1973 Honda CB350f
« Reply #9 on: July 11, 2014, 11:36:00 AM »
No didnt make any mistake with the torque wrench.  I used my fancy craftsman 200 dollar torque wrench because I am always scared of cheap torque wrenches.
Offline Ericcb750
« Reply #10 on: July 11, 2014, 11:38:58 AM »
Hey, sorry to hear that. I actually got parts recently from David Silver Spares and I remember seeing a Top Triple tree on there. If you go on that site and put in your bike info, all the parts available will come up, they might have one. the top tree I saw was for a 78 750K and was only $95.00. Good luck man, hope it works out for you. Sorry I'm on my first one so I don't have any spare parts. I'm sure you'll be able to finde one.
1978 CB750K
1978 CB750F super sport
2005 Sportster 1208
« Reply #11 on: July 11, 2014, 12:01:14 PM »
Already checked their site they do not carry the top bridge :(
Offline jamesbekman
« Reply #12 on: July 11, 2014, 12:02:48 PM »
What has you $4k in the hole?  Id love to see some pics!
Offline goldarrow
  • one day, i'll be an
« Reply #13 on: July 11, 2014, 12:31:31 PM »
D washers?
yes, you probably missing the D washer.  look in the fiche and you'll see it
CB550 K0
« Reply #14 on: July 11, 2014, 12:48:36 PM »
Bummer  :-\
no D-washer, guys.
Offline goldarrow
« Reply #15 on: July 11, 2014, 12:53:03 PM »
My bad...
CB550 K0
Offline Thamuz
« Reply #16 on: July 11, 2014, 01:04:47 PM »
Let me look through my 350f parts.  I have one that I got for parts.  I might have one.  at work till WAY late.
1979 Yami Chopper XS1100s
1978 CB750k
1977 CB550F
1974 CB550k
Parts bike for the 550's
« Reply #17 on: July 11, 2014, 02:43:37 PM »
um not much just had to replace a fair amount of parts then a lot of rare parts like original giulari seat for the cb350f and mivv exhaust system throw all the powder coating, painting , and new parts and it adds up very very fast, too fast im starting to think 4k is an underestimate :(
just checked ebay not seeing and top bridges :(
Offline lucky
« Reply #19 on: July 11, 2014, 06:19:24 PM »
It is easy to spend 3 grand on a restoration done properly.
Now days many parts are $100
But that triple tree is easy to get. There are lots of them.
I would not use a torque wrench either. Just tighten it by hand.
Make sure about those "D" washers.
Many people have broken those castings because washers were missing.
« Reply #20 on: July 11, 2014, 07:06:01 PM »
D washers?
cb350f? ooops  might go ahead and freak.  I've never even touched one of those before.  I assumed 500/550/750.
« Reply #21 on: July 11, 2014, 07:15:12 PM »
William you must be my motorcycle guardian angel first the ignition bracket and now you might have a top bridge...totally lifting my spirits!
-james
« Reply #22 on: July 11, 2014, 07:16:56 PM »
So is this pretty normal? I did have the part powder coated professionally where they strip it and all that stuff.  could powder coating of actually weakened the piece ?
« Reply #23 on: July 11, 2014, 07:20:57 PM »
for you guys mentioning D washers here is the parts fiche for the cb350f
« Reply #24 on: July 11, 2014, 07:33:53 PM »
What is the range of your "fancy" torque wrench? For such low values, the torque wrench should have a maximum of about 25 ft/lbs.
