Author Topic: knee deep in my 1st carb rebuild (78 cb550 pics)  (Read 1123 times)
Offline redrider736
« on: July 11, 2014, 12:52:31 PM »
OK. On summer holidays, wife away, 2 brown pops in and.......
Something LQQks different????
This is my 1st CB,  and my 1st time ever tearing into a bike......  I read up and watched a few great vids about cleaning/rebuilding your carbs........  What you are looking at are 78 CB 550k carbs....
Question......  Why is carb #3 different from the others?
« Last Edit: July 11, 2014, 01:15:47 PM by redrider736 »
78' CB550k (Not Run'n / Basket Case Project)
77/78 cool 2 member #269
Re: knee deep in my 1st carb rebuild (78 cb550 pics)
« Reply #1 on: July 11, 2014, 12:55:11 PM »
be careful not to mix up the parts.  if it came out of a carb, put it back in that same one.
its different because its the slave carb, meaning, all other carbs in the rack are tuned to match that one, and it should be #2, looking left to right, while sitting on the bike
Offline Jimsun
« Reply #2 on: July 11, 2014, 12:57:44 PM »
The #3 you said is actually carb #2 and that is the preset which the other 3 needs to follow when you synch the carbs
74 cb550
Offline redrider736
« Reply #3 on: July 11, 2014, 01:10:16 PM »
My bad on the numbering ( learning a bunch today :) I have individual containers for all 4 carbs....
2nd question; how do I remove the "slow  jet" ? Its round in shape and didn't want to force  anything out without really knowing how too.......  Do I need to "bang" it out?
Offline MiGhost
  • What was that about being an
« Reply #4 on: July 11, 2014, 04:09:22 PM »
The slow jet is pressed in. You can use pliers to twist, and pull it out. Use a shop rag, or similar between the jet, and pliers to keep from marring the soft brass.
DO NOT pound directly on the jet when reinstalling. It WILL damage the jet. Use a soft piece of wood to buffer to blows.
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
Offline redrider736
« Reply #5 on: July 11, 2014, 06:12:09 PM »
Thanks all,  info help out greatly.....  I bought a Keyster deluxe rebuild kit from 4into1....... Then read a post saying that I should sick with OEM and that the Keystars are junk.....  Any thoughts?
« Reply #6 on: July 11, 2014, 06:32:49 PM »
Learned that lesson back when I had my 350F  :-\
I'll never buy anything but OEM.....
Offline redrider736
« Reply #7 on: July 11, 2014, 06:48:18 PM »
S*#t ! Expensive lesson learned....  We're is the best place to order OEM?
Quickly found
http://www.cmsnl.com/honda-cb550k-1978-usa_model7222/partslist/
« Reply #8 on: July 11, 2014, 08:26:37 PM »
I prefer jetsrus.com
Offline Deltarider
« Reply #9 on: July 12, 2014, 02:20:43 AM »
Why in the world did you remove these parts (in the photo)? They never ever need servicing.
CB500K2-ED Excel black
« Reply #10 on: July 12, 2014, 02:34:01 AM »
gaskets and o-rings will probably work...don't use the brass.   Plenty of Honda dealerships online for oem stuff.
Offline redrider736
« Reply #11 on: July 12, 2014, 07:42:08 AM »
I can't leave anything alone,  wanted to learn how to tear them down and too see what condition they were in
Offline billingstitan
« Reply #12 on: July 12, 2014, 08:58:19 AM »
It's a worthwhile endeavor to tear those carbs apart - you learn a lot and become comfortable enough that the intimidation factor goes away.
Carbs are the key  ;D
Just be gentle - that old metal cracks easily. An air compressor is invaluable during the cleaning process. So are replacement screws for the float bowls and top caps. I have a bag of spares I keep on hand.
Calling upon my years of experience, I froze at the controls.  ~Stirling Moss
2014 Ducati Monster 796
1977 CB550K http://forums.sohc4.net/index.php?topic=138289.0
1977 CB550K
1972 CL175
2000 Kaw Nomad 1500
1992 KDX 200
2001 Honda 80R
Past Bikes:
1973 Kaw 900Z1
1970 Yamaha 350RD
2003 Yamaha VStar 1100
2001 Suzuki GS850
Offline redrider736
« Reply #13 on: July 12, 2014, 12:01:51 PM »
Got her out! I was just being too "gentle" with them...  Worried I was doing something wrong..
I cut a small piece of leather off an old baseball glove as to not damage the jet
« Last Edit: July 12, 2014, 12:16:27 PM by redrider736 »
Offline redrider736
« Reply #14 on: July 12, 2014, 12:21:52 PM »
Is there anything else that needs to come out before cleaning / dipping the metal parts ??
How do I remove these ???
Also....When I removed all the parts I took a inventory of the parts pre/Carb and noticed that I was short 1 shim/washer & o-ring in #4 Carb, and 1 shim/washer in #2 Carb in the Idle mix screw ????
« Last Edit: July 12, 2014, 12:24:43 PM by redrider736 »
Offline MiGhost
« Reply #15 on: July 12, 2014, 06:00:10 PM »
If you are refering to the idle mixture screw washer, and o-ring. They are likely still stuck up in the carb body. You can use a small pic to dig them out.
When reinstalling the correct order is spring, washer, o-ring .
The washer protects the o-ring from being cut by the spring.
The original brass pieces are likely to be in good condition still.
The gaskets, and o-rings in those keyster kits will be fine.
~ Ghost
