Author Topic: heat and loss of power  (Read 2402 times)
Offline tony sawyer
« on: July 11, 2014, 01:55:52 pm »
hi havn't been around for a while .posining a question for the learned collective at sohc4 especsily those racing in a hoter parts.
the british summer is apon us the track temprature is rising
this is when my heat problem start
it seams like last year as soon as it raises o above 25centigrade my outfit seem to lose power when hot ,engine dies without reving
im wondering if its a carb problem jetting i'm running 31mm cr's or could it be fuel evapourtion
we dyno at 81bhp at a very cool dyno room
think got to fit a bigger oil cooler
any experience similar problem or have a solution
Offline Tintop
Re: heat and loss of power
« Reply #1 on: July 11, 2014, 02:02:50 pm »
Where is your fuel pump located??  Could be vapour lock if the pump is getting heat soaked by the engine.  A couple of bikes over here have had that issue last year when it got above 25C.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Offline tony sawyer
« Reply #2 on: July 11, 2014, 02:36:01 pm »
the pumps not on direct heat its on the platform but its food for thourght thanks for responce cbr600 ticker pump
Offline bear
  • Leeton in Australia
« Reply #3 on: July 11, 2014, 06:41:16 pm »
I'm with Brian on this one.
Fuel delivery will most likely be the problem.
25 deg? How are you going to handle 40 over here in January Brian? ;D
Brian
« Reply #4 on: July 11, 2014, 07:40:03 pm »
If you consider 25C hot, what was the temp in the "very cool" dyno room? :o Also, vapor lock can happen anywhere in the fuel line, where a bubble of air can be trapped.
Offline bear
« Reply #5 on: July 11, 2014, 07:49:45 pm »
We run 33CR's.
Engine temp. and fuel delivery are two major problems down here.
We run the biggest cooler we can comfortably fit and partly screen it off in the colder weather.
Our fuel system consists of two Facet pumps installed in series,  wired separately ie two switches.
12mm fuel line to a small header tank (about 400ml) then a 10mm return line back to fuel tank.
The return line is fitted with a tap which can be switched off to force the system to operate at the fuel pump's max pressure if required.
This system gives us a very flexible fuel delivery system.
◆Normal race conditions,  1 pump on return line tap open
◆Hot weather, both pumps on return line tap open. (Increases fuel volume to reduce fuel temp. & vaporization.)
◆Track with high speed corners, 1 or 2 pumps on return line tap off. (Increases delivery pressure to stop fuel surge.)
Hope this might help.
Brian
Offline Tintop
« Reply #6 on: July 11, 2014, 08:18:34 pm »
Brian
Seems to me it was only 22C at the last PI Brian.  Our July race last year was over 30, lost a couple of pounds, but that only makes the rig faster. ;) :D
+1 scottly  I'd also take a look at fuel line routing, from the pump to the carbs.
77 CB550 Cafe build
Offline bear
« Reply #7 on: July 11, 2014, 08:26:44 pm »
Brian
PI January mate, you can get four seasons in one day.
18deg and raining in the morning, then 40deg and windy in the arvo.  :D
Brian
Offline tony sawyer
« Reply #8 on: July 11, 2014, 09:43:25 pm »
thanks for responce thats a couple of points to look at
have you reduced the needle valves on the cr's
had a lot of agro with facet pumps went back to a ticker which maybe the the cause
Offline bear
« Reply #9 on: July 11, 2014, 11:04:19 pm »
We run methanol so our needle valves are on the large side.
I think the secret to using Cr's with facet pumps is the recycling fuel delivery I mentioned in the previous post.
I think the facets can be a little dodgy when it comes to reliable pressure management, but they produce good volume.
Brian
Offline Tintop
« Reply #10 on: July 12, 2014, 08:41:50 am »
Brian
So pack long johns, and shorts is what your saying. ;D ;D ;D ;D ;D
As for 'dodgy' fuel pressure, I always run a pressure regulator with a gauge (between pump & carb), and use a pump that's rated about 50% more than I need.  A surge tank is helpful, but baffles, or foam in the main tank can make a big difference to getting consistent fuel pressure.
77 CB550 Cafe build
« Reply #11 on: July 12, 2014, 08:35:48 pm »
Tony, are you noticing a serious loss of power, then the rig runs better after cooling off? If so, are you running a Dyna ignition?
Offline tony sawyer
« Reply #12 on: July 14, 2014, 08:46:07 am »
no got a simple boyer
is there an inherant problem dyna and heat?
 je pistons two ring hi comp   cx 7 cam
we're moving the pump and putting it upright for starters
Offline Tintop
« Reply #13 on: July 14, 2014, 01:28:32 pm »
Sounds like a good start.  From my experience electric fuel pumps only operate properly when mounted as originally intended.
The Boyer's either work or they don't, although I did have an issue with mine.  Cause was the wires from the P/U plate (7/10 yrs old) had become brittle from heat (cracking insulation) and I started to get intermittent ignition cut-out.  Replaced P/U, problem solved.  The Dyna S had issues (couple of years ago) failing from heat under the points cover.
77 CB550 Cafe build
