Author Topic: Carb cleaning  (Read 14774 times)
Offline Rsnip988
Re: Carb cleaning
« Reply #50 on: September 20, 2006, 01:54:55 AM »
I wish to break down my first set of carbs and clean them as the bikes been sitting for years.   I have read from many many posts that the Yamaha carb cleaner is the stuff to use so i'll run out and get some today... I had a question as to whether putting the parts in a sonicator (machine that vibrates the liquid inside resivoir with sound waves) filled with the carb cleaner would help the cleaning the hard to reach jets?
PLease let me know as i can bring the parts into work (Chemistry Lab) and ust the sonicator here since we dont use them too often.
Thanks in advance
RKS
R.K.S.
1976 CB750 K6 Full
1976 CB750 K6 Cafe'ish
Offline enforcer
Re: Carb cleaning
« Reply #51 on: September 20, 2006, 05:10:52 AM »
Check out this website if you haven't yet.  It is great for a first timer.  It is listed under the FAQ on carbs.
http://www.salocal.com/sohc/tech/carb/carb.htm
Offline cmorgan47
  • smaller, lighter, quicker
    • theundergr0und
Re: Carb cleaning
« Reply #52 on: September 20, 2006, 06:05:30 AM »
i'd pull all the jets out, then run them through the sonic cleaner.  used to work for a jeweler and they used something similar to clean the gunk out of jewelry.... should do a good job of getting the crap out of the little holes.
suppose if the cleaner's large enough you could throw the bodies in too, but i'd pull all the jets out first.
also, i think you're supposed to boil the yamaha stuff so you probably wont be able to use that in the sonic cleaner....maybe regular carb dip though.
i love babies...
with a nice chianti sauce and a side of fava beans
Offline Rsnip988
Re: Carb cleaning
« Reply #53 on: September 20, 2006, 06:19:34 AM »
Hmmm I cant seem to get the stupid rack off of the intake and throttle cable, i unscrewed the clamps but it wont let go
R.K.S.
1976 CB750 K6 Full
Offline cmorgan47
    • theundergr0und
Re: Carb cleaning
« Reply #54 on: September 20, 2006, 06:23:48 AM »
huh?
i think it's easier to pop them off the intake, then get the cables off....gives you a little more room to work with.  if you're saying that the manifold boots are holding too tight, that's pretty common.  the last set i did, a buddy and i sat on either sides and just yanked on them for a while....eventually they popped off.  maybe try a rubber mallet to get them going.
i love babies...
Offline flatblack
Re: Carb cleaning
« Reply #55 on: September 20, 2006, 06:59:34 AM »
The most popular and complete kits come from Keyster.  Here's a good source:
http://www.siriusconinc.com
I just checked: Of course, they're sold out of the "economy" kits for your bike but they do have the full kit, p/n KH-0983N, in stock at $23 each. The full kit includes all jets, o-rings and bowl gasket for one carb while the economy kit includes only four bowl gaskets and four float valves.
From your symptoms, you need all the o-rings and the bowl gaskets. You also need a length of hose to replace the fuel transfer tubes but can get by without a jet kit.
For a how-to, see this link:
http://www.sohc4.us/forums/index.php?topic=5410.0
To do this right, you'll need:
1. A clean, flat, well-lit workspace for a few days.
2. A gallon can of carb dip (local auto parts store).
3. Several cans of spray carb cleaner (Berkebile 2+2 seems to be the best I've used...).
4. Plenty of patience and the ability to do close-up work with small parts.
None of this is difficult, nor does it require special knowledge. Just take your time and think of all the money you're saving. Pay special attention to the material found in the "how-to" link, above, and ask copious questions here whenever you feel the need.
HTH...
fb
'76 CB400F
'78 CB750K
'04 CBR600F4i
'76 Yamaha RD400C
'79 Yamaha RD400F Daytona Special
'84 Yamaha RZ350
Dirt bikes?  Sure...
Offline Bob Wessner
  • "Carbs Suck!"
Re: Carb cleaning
« Reply #56 on: September 20, 2006, 07:31:34 AM »
I hate to sound like a broken record, but the hard parts of the carbs rarely wear out. Unless you know that yours are shot for some reason (either true wear or corrosion, etc.) consider just cleaning and replacing the soft stuff. If you do go ahead with Keyster kits, pay close attention to the float valve and spring (I found the spring to be very stiff, unlike the stock), as well as the main needle taper. I found these to be off quite a bit, more slender toward the tip (i.e., richer). As a result, I just used the stock parts after cleaning. You can compare the needle tapers using a drill bit guide.
Offline Rsnip988
Re: Carb cleaning
« Reply #57 on: September 20, 2006, 08:49:34 AM »
No I got it off of the intake boots, i  cant get the stupid throttle cables off the carb rack to work on it, all of the screws/bolts are/were rusted in place now half of them are stripped due to dumb old me,  Any Impus at all on how to get them off without just snipping the throttle cables completely?
R.K.S.
1976 CB750 K6 Full
Offline flatblack
Re: Carb cleaning
« Reply #58 on: September 20, 2006, 09:43:15 AM »
What he said. It's highly likely that your hard parts are fine and just need to be cleaned. Replacing the rubber parts will probably fix your leak. I should have said that up-front.
fb
'76 CB400F
'78 CB750K
'04 CBR600F4i
'76 Yamaha RD400C
'84 Yamaha RZ350
Dirt bikes?  Sure...
Offline Loudpipe
  • Broken Vehicle Collector
Re: Carb cleaning
« Reply #59 on: September 20, 2006, 07:23:33 PM »
Ok, that's encouraging.  I've got to pay for a top installation on my TR6, as well as get insurance and some other payments made before I can order the carb kits, but that should make a good winter project.
- LP
1974 Honda CB350F
Previous: 1978 Honda CB750F, 1971 Honda CB500K, 2009 Yamaha YZF-R1
Offline Rsnip988
Re: Carb cleaning
« Reply #60 on: September 23, 2006, 04:37:46 PM »
i got them off and cleaned, I'm waiting for the new kits to get here so i can rebuild with new parts, i found out why the 3rd carb kept flooding ..... the Float needle was missing/broken open  either way i cant find it so i'm awaiting the new kits i found on ebay...  I got all four kits together for only $35 S&H included
Beat that
RKS
R.K.S.
1976 CB750 K6 Full
Offline nippon
    • Classic Cycle City
Re: Carb cleaning
« Reply #61 on: September 23, 2006, 11:39:38 PM »
I think the best and easiest way to clean them is blasting with walnut shells
after you have disassembled the carbs and after locking all holes.
If you disassemble all 4 carbs at the same time, be shure that you don't
interchange the parts to the wrong carb when you are going to put them together again.
I used the Keyster kit, too. We'll see how it works.
To put the carbs battery back on the intake boots, the best ways is to warm up
the intake boots with a hair dryer a little bit, or grease the inside of the intake boots
with WD-40 (less is more). Then the carbs glide easily in.
nippon
Offline Lumbee
    • My pics...
Re: Carb cleaning
« Reply #62 on: September 24, 2006, 04:37:33 PM »
 :o  ...thats one clean set O carbs nippon!!!!
"I'm not a welder, but I play one on HondaChopper.com"
Offline Rsnip988
Re: Carb cleaning
« Reply #63 on: September 26, 2006, 01:29:06 AM »
They look so BEAUTIFUL!!!!!  almost brand NEW
I so jealous
RKS
R.K.S.
1976 CB750 K6 Full
Offline Loudpipe
Re: Carb cleaning
« Reply #64 on: September 26, 2006, 08:16:29 AM »
Yes.  I've never put carbs back on a Honda, but there are several parts on Triumph (the 4-wheeled varient) and MGs that require this technique.  If you put it in water and boil it or nuke it in a microwave, it works even better.
- LP
1974 Honda CB350F
