Author Topic: Running on 3 cylinders at idle.  (Read 1578 times)
Offline Calumjs
« on: July 13, 2014, 01:45:27 AM »
My cb550 is only running on 1,2 and 4 at idle, I pulled the 3 cylinder plug and it's got nice spark but is dry as dead dogs donga. It runs on 4 when it's revving high , but when I'm in the low rev range it's hesitates a bit then pulls very well. I'm guessing carb 3 has issues, any idea what I need to look at? It's not ignition as it has dyna coils and electronic ignition and it has a great spark just no fuel at idle/low revs!
Any help will be great!
Offline harisuluv
Re: Running on 3 cylinders at idle.
« Reply #1 on: July 13, 2014, 01:53:49 AM »
You all have all the symptoms of a clogged idle jet.
Offline Vinhead1957
« Reply #2 on: July 13, 2014, 05:03:17 AM »
+1 on the clogged carb
Clean and run some seafoam when you fill up
Offline Deltarider
« Reply #3 on: July 13, 2014, 06:07:19 AM »
What model 550 is it? Keihin carbs? PD?
CB500K2-ED Excel black
Offline Calumjs
« Reply #4 on: July 13, 2014, 06:11:20 AM »
Thanks guys, can I access the idle jet from removing the bowl while the carbs are still on the bike?
Offline Calumjs
« Reply #5 on: July 13, 2014, 06:12:00 AM »
It's a 74,
Offline Deltarider
« Reply #6 on: July 13, 2014, 06:21:44 AM »
Sure, it's easy. Remove the float bowls and use a small screwdriver to remove the slow jets. No need to remove the carbs. I can do it with my eyes closed. In order to get at #3 you have to remove the #4 bowl too. While you have them opened you might as well inspect the mainjet (o-ring) and the needle jets aka emulsion tubes. http://forums.sohc4.net/index.php?topic=138165.msg1560006#msg1560006
« Last Edit: July 13, 2014, 06:26:13 AM by Deltarider »
Offline Calumjs
« Reply #7 on: July 13, 2014, 04:47:46 PM »
Great! Thanks for the info! One last issue is that my idle is rather high even with the idle adjuster screw screwed all the way out so it's not even making contact with the bar. Is there a way of adjusting the idle other then that one adjuster screw on the right side of the bike? Thanks again
Offline goldarrow
  • one day, i'll be an
« Reply #8 on: July 13, 2014, 09:03:41 PM »
Yes. Do carbs synch to bring idle down
CB550 K0
Offline harisuluv
« Reply #9 on: July 13, 2014, 09:20:19 PM »
If you synced your carbs they were done so without being synced relative to the adjuster screw.  That is why you have no range of adjustment.  When the screw is in contact and you have a range of contact in and out, that is where they need to be synced at the same height.
Offline Calumjs
« Reply #10 on: July 13, 2014, 10:39:16 PM »
Okay so I want to sync with the adjuster screw at half way? So I can adjust 50% either way?
Offline harisuluv
« Reply #11 on: July 14, 2014, 03:28:27 AM »
From the point where the idle adjust makes contact to where it bottoms out.  That is the theoretical adjustment range possible for the idle adjust screw.  That is where they have to be synced not only to each other, but the correct height ie. drill bit or whatever you're using to to bench sync.
