Author Topic: Carburetor Adjustment  (Read 782 times)
Offline Roadrage23
« on: July 13, 2014, 08:52:40 am »
Hi,
I have a question about two screws on the carburetors, one on the throttle plate and the other on the carburetor mount plate. This is shown below in the pictures.
What are these for and how do you set them up correctly?
The bike is a 1975 CB750f1.
Regards,
Roadrage23
« Last Edit: July 13, 2014, 08:56:45 am by Roadrage23 »
Offline greenjeans
  • 1972 CB750K2
Re: Carburetor Adjustment
« Reply #1 on: July 13, 2014, 07:11:48 pm »
Both are stops.  Top one looks about right - it's position is fixed - fail safe - keeps the arm from driving the needles into the main jets.  The bottom photo - it limits the height that the throttle cable can pull the slides open, it's adjustable.  You don't want to rip them out of the carbs.
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #2 on: July 14, 2014, 04:58:21 am »
The top one CAN be adjusted. Honda spec is 2-3mm clearance.
--Evan
1975 CB750K "Rhonda"
Offline Roadrage23
« Reply #3 on: July 14, 2014, 07:28:03 am »
Hi,
Thanks for the quick responses!
Okay, so the top picture is showing about two mm's clearance so that is fine.
Is the bottom screw meant to have clearance too or suppose to come in contact with the throttle plate? Currently there is a few mm's clearance.
Regards,
Roadrage23
Offline evanphi
  • Apparently I'm an
« Reply #4 on: July 14, 2014, 08:20:57 am »
Hi,
Regards,
Roadrage23
It should be turned so that it doesn't allow the linkage to open too far at WOT. Screw it in when your carbs are completely reassembled, and make sure the linkage doesn't a) slip out of the adjusters and b) hang up when you release the throttle.
--Evan
