Author Topic: Help! How to change the shift shaft on a 1972 honda cb350  (Read 1340 times)
Offline Only_Slightly
« on: July 14, 2014, 12:01:34 PM »
I have the replacement shaft in hand. I want to replace the part myself.
Can I do this myself and how do I go about it?
Offline Oldtech
  • Motorcycle tech: old, cranky and retired
Re: Help! How to change the shift shaft on a 1972 honda cb350
« Reply #1 on: July 14, 2014, 01:03:17 PM »
Before you do anything get a service manual.
Pull off the right side engine cover and remove the clutch with the oil pump. Take off the left side sprocket cover. There may be a circlip on the shaft at the seal - can't remember off the top of my head. If there is remove it. Then disengage the rachet pawl from the shift drum and slide the shaft out from the clutch side. Slide the new shaft in and replace the seal while you're at it.
« Reply #2 on: July 15, 2014, 01:37:05 PM »
I have located a manual :)
Will I need any type of specialized tool, or will a normal tool box do the trick?
Thanks for the info!
- Jessika (new rider)
