Author Topic: Blinkers  (Read 2123 times)
Offline my78k
Blinkers
« on: May 16, 2005, 07:12:31 AM »
Any thoughts on how I can isolate whether or not my winker relay has died? When I put on the signals they do light up but they do not flash...just stay on bright. Not sure if there is any other explaination i.e. charging issue etc.
I  realize that one quick way is to replace it and see what happens but the closest one I can find is a 40 minute drive from my house...if all else fails I will have to go that route but was hoping to avoid that path.
Thanks,
Dennis
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: Blinkers
« Reply #1 on: May 16, 2005, 07:18:35 AM »
We call them "indicators"  :)
If both lamps come on but don't flash, the bimetal strip inside the relay is not heating enough to "bend" and break contact.
This could be because you battery voltage is too low. Try a recharge.
Lamp ratings correct? Incorrect current flow could cause this symptom.
Could be a knackered relay of course.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline Gordon
  • 750K1, 550K2
Re: Blinkers
« Reply #2 on: May 16, 2005, 07:22:51 AM »
You don't need a special relay for your bike.  Any 12 volt blinker relay with the same number of wire terminals will work.  If you do get a new one, go with the newer solid state variety.  They don't wear out like the old style and they blink at the same rate regardless of engine rpm.
Offline Raul CB750K1
Re: Blinkers
« Reply #3 on: May 16, 2005, 07:29:50 AM »
That's right, remove that two-lead heating reed type and go to the new three-lead. The timing is set by in IC rather than by the heating time, so it is fixed irrespective of voltage. You should even have a green wire hanging near the other two terminals. That's the earth conection, so plug a new type and you are good to go.
Raul
Offline frostypuck
Re: Blinkers
« Reply #4 on: May 16, 2005, 01:08:22 PM »
If you are new to the bike, make sure the proper bulbs are in their sockets. I think 1157's in the back and 1093's up front, but double check me on that. Also, if one bulb on a side is blown it'll occasionally make the light come on and stay on rather than flash. Also, my '78 wouldn't flash until the engine speed was up, changing to a $7 flasher from Auto zone solved that.
Chris in Boston
Boston, MA, USA
Offline Serge
  • cb750f 1978
Re: Blinkers
« Reply #5 on: July 03, 2005, 11:29:21 PM »
Hello,
I am trying to chase down a glitch I have with a blinker. It works fine on left with a sound and light on the panel. On the right, however it is only turning on but not blinks. Sometime it starts to blink with sound but bulb on the panel do not light.
I looked through forum and checked and replaced all four bulbs to no avail. I tried to install 550 automotive flasher as someone adviced, but have blown main fuse in all possible combinations. I tried to tinker with relay but it did not get any better. Please, advice ! If it is a flasher problem, we can I get a new one?
Thanks a lot !
Serge
if it ain't broken it does not have enough features yet..
Offline 78 k550
Re: Blinkers
« Reply #6 on: July 04, 2005, 06:46:18 AM »
I just replaced mine because it was turning them on but not blinking. I grabbed a flasher from a yard and noew it blinks.Thr ight side is a little faster than the other. I checked dealer $35.00 and 4 at local shop. I think K&L had them.
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
bike54
Re: Blinkers
« Reply #7 on: July 04, 2005, 08:24:50 AM »
looks like a bad earth to me possibly in the head light unit its a right rats nest of cables in there but i would start at the blinker checking and work my way back to the flasher unit good luck they can be pigs to find
bike 54
