Author Topic: Need help getting it to run right  (Read 1053 times)
Offline guitarking135
« on: July 14, 2014, 06:17:57 PM »
So I figure I would start here since y'all have a lot more experience with these bikes than I do. So what I got is a 78 cb750 that I've made into a bobber… I got it running but it doesn't run very well. Let's start with the set up
Stock engine-that I'm aware of.
4 Drag pipes
Stock carbs w/ 4 open filter elements
The problem is the bike will not run with out the choke pulled out all the way. When I push the choke in to start it sounds like it's sucking in ALOT of air. You can hear a whistling noise. I'm assuming that it's probably an air fuel mixture issue but I'm kind of at a loss as to where to start. Is there any test that I can do to try to isolate the problem. rich or lean?
Offline Tempast
Re: Need help getting it to run right
« Reply #1 on: July 14, 2014, 06:31:00 PM »
Well for one, you're getting WAY more air into the engine than stock, and with drag pipes and no backpressure WAY more air OUT of the engine.
The problem is most likely you not getting enough FUEL into the air going into the engine. Time to play with the jets. Stock size is 120 on the 750 I believe (not sure what year)  Try going up a couple sizes and see if it runs better.
Holding the choke makes it harder for the engine to breath, so you'll get more less air into it, and making the air/fuel ratio better.
Offline dusterdude
« Reply #2 on: July 14, 2014, 06:35:26 PM »
Yea,you're way lean.richen that bad boy up a bit
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Tempast
« Reply #3 on: July 14, 2014, 06:54:43 PM »
Wow my grammar in that post. "more less air" GJ. What I meant was you'll get less air, and more fuel.
Offline harisuluv
« Reply #4 on: July 14, 2014, 07:03:51 PM »
You are still on stock settings?  With that setup you would need to raise the needles and increase the main jet size.
« Reply #5 on: July 15, 2014, 01:27:57 PM »
I went up to a 120 jet from a 110 per the suggestion of a vintage Japanese bike mechanic. Let me go back. I went out to start it this morning and it wouldn't fire up. After putting in the `120 jets It acted like it wanted to start but just wouldn't go. Is it possible part of my problem could be in the Air/fuel screw?
« Reply #6 on: July 15, 2014, 01:32:08 PM »
Oh and the only way it would sputter and act like it wanted to start was with the throttle close to all the way open
« Reply #7 on: July 15, 2014, 01:47:55 PM »
How do I go about raising the needles?
« Reply #8 on: July 15, 2014, 02:07:11 PM »
if you have the correct PD carbs for that bike, you cannot change needle clip position , its fixed, so shimming the needle is the only way.
here's how...
http://forums.sohc4.net/index.php?topic=71245.0
Good PD carb info thread, as you have 2 other important systems on those carbs.  An accelerator pump, and a fast idle cam.
http://forums.sohc4.net/index.php?topic=48858.0
...and with your exhaust and intake,  you'll be very close to the setup listed in my sig  ;)  with maybe #130 main jets
« Last Edit: July 15, 2014, 02:10:21 PM by flybox1 »
Offline harisuluv
« Reply #9 on: July 15, 2014, 03:28:39 PM »
Just making that main jet change shouldn't cause it to not even start.  The main jet should only affect 3/4 to WOT throttle range anyways.  You have other problems, most likely at least dirty idle/slow jets.
« Reply #10 on: July 15, 2014, 04:15:27 PM »
I got it starting and can push the choke in a little. Might try the 130 jets and go from there. I think it wasn't getting fuel before. Let it sit and it fired right up.
« Reply #11 on: July 16, 2014, 09:42:42 AM »
I'll go ahead and throw this out there too. I was playing around with it today i can get it to start but it runs really high idle then eventually comes down then dies. Almost like it's out of fuel. Sputters and puts. If I try giving it gas it dies but if I pull the choke out more it will come back to that really high idle. Do you think it might be an issue with getting fuel to the carb?
Offline lucky
« Reply #12 on: July 16, 2014, 01:03:20 PM »
You cannot expect it to run right by just changing the main jet. That would have almost no effect at all.
Offline lucky
« Reply #13 on: July 16, 2014, 01:14:18 PM »
I am going to tell you how to make it work.
First make sure the accelerator pump system is working. Both one way check balls have to work. ONLY the #2 carb has the accelerator pump. IT is the master carb.
 Check the spray nozzles with a bright LED pocket flashlight. With the KEY OFF,  make sure that when you turn the engine over that each nozzle squirts gas.
Make sure you measure the float height as given in the Clymers' manual.
Measure them like the book shows.
Make sure all of the float needles are new.
Remember they could be 40 year old parts. Toothpaste is not going to fix them.
Make sure to remove all 4 mixture screws and dig out any old O rings.
Put in 4 new O rings with the spring and washer on each mixture screw. You can just buy a set of 4 mixture screws and you get all new everything with them.
Put in #42 idle jets.  40's will not work.
Mixture screws all at 3/4 turns out.
Slide needle will need to be shimmed or replaced with 1977 or 1976 slide needles.
Needle clip one notch down from stock.
It will make your job easier.
Main jets #125.
Sync the carbs LAST.
« Last Edit: July 16, 2014, 01:20:46 PM by lucky »
« Reply #14 on: July 16, 2014, 01:40:46 PM »
Where can I get shims and idle jets at?
