Author Topic: 400f gear linkage  (Read 2347 times)
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
400f gear linkage
« on: September 23, 2006, 02:10:10 PM »
reference the attached picture from the Honda parts fiche.
I have tried my gearshift as pictured and also with arm (22) the other way round.
It seems to be a more positive shift with it the opposite to the picture, also the line of the rod is parallel to the lever that way, has anyone else experimented in this way?
I also require the 2 rubber boots to protect the ball joints, where can these be got from?
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline colb
Re: 400f gear linkage
« Reply #1 on: September 23, 2006, 02:54:48 PM »
Offline Tim2005
« Reply #2 on: September 23, 2006, 03:43:51 PM »
I haven't tried it... but it must run extremely close to the sprocket cover like that? By "the other way round" you do mean back-to-front, rather than upside down, don't you (else that'd change it to a 1-up-5-down change, though that would probably change up gears higher as foot pressure that way is more positive)?
« Reply #3 on: September 23, 2006, 04:36:30 PM »
For boots I got a perfect used set from a newer GSXR.
Like Tim I'm fuzzy about you're situation. Did you remove & rerivot the joint from the shifter arm? Seems to me like the joint angles are straightest in the original position. Give us a look.
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #4 on: September 24, 2006, 05:52:52 AM »
ok sorry about explanation but I had trouble putting it into words.
I just turned round lever (22) back-to-front, I have posted pictures now to show.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline Kevin400F
« Reply #5 on: September 24, 2006, 06:27:32 AM »
Ok, so is everyone else as clueless as I am on what the original poster is trying to say?  I see  three pics that match the OEM configuration.  What's all this "other way round" biz??
Kevin
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #6 on: September 24, 2006, 06:50:32 AM »
look at parts fiche and try to imagine the ball joint facing into the engine instead of away from!
When I get time I will turn it, (lever part #22), round and post a picture of that too.
« Last Edit: September 24, 2006, 06:53:03 AM by malcolmgb »
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
« Reply #7 on: September 24, 2006, 07:19:40 AM »
I szeem to remember that if the front bit is reversed the ball joint hits the casing.
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #8 on: September 27, 2006, 09:25:01 AM »
Try the folowing for the dust covers
http://www.cmsnl.com/cb400f-cb-1-us_model1010/partslist/F++19.html
colb
thanks for that colb, I called at a local dealer who had them in stock, a little more expensive but no postage, perfect fit.
I have now turned round the lever (22) as can be seen in pictures, and really feel the change is an improvment both visually and mechanically.
« Last Edit: September 27, 2006, 11:47:52 AM by malcolmgb »
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline cmorgan47
  • smaller, lighter, quicker
    • theundergr0und
« Reply #9 on: September 27, 2006, 09:35:01 AM »
 really feel the change is an improvment bothe ... mechanically.
how so?
better shifting?
does it hit the casing at all?
did it change where the shift lever sits at all?
i love babies...
with a nice chianti sauce and a side of fava beans
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #10 on: September 27, 2006, 11:57:23 AM »
how so?
better shifting?
This is the way I built it up originally because it looked right, I then noticed photos that had it other way around and thought I've got it wrong again, so put together the Honda way, while riding I had a few false neutrals and the change didn't feel as positive, that is reason for original post.
No sign of hitting the casing and I can position the lever in a comfortable postition for mysef. I know of another forum member who runs their bike like this, but would still like to hear of other peoples views.
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
