Author Topic: from cardboard boxes to a cb750  (Read 6318 times)
Offline KirkBurner
« on: July 17, 2014, 12:25:01 PM »
Well.. I was "lucky" to come a cross a project at the quarter of the cost of a running bike.
Story behind this was that the guy had 6 other projects and this one had stalled and he needed to get it out of sight.
The fist goal here now is to get it running, and getting plates on it. Goal is March for the plates with a running motor.
Then to see if it will get modified in any way or passed on for new projects.
the worst thing about this project is.. its summer and I have two bikes with engines open...
« Last Edit: July 17, 2014, 12:27:16 PM by KirkBurner »
Offline KirkBurner
Re: from cardboard boxes to a cb750
« Reply #1 on: July 17, 2014, 12:53:07 PM »
Golden parts?
the PO got replacements.. but when would people get these parts...?
Offline KirkBurner
« Reply #2 on: July 17, 2014, 01:30:25 PM »
Painting beeing done....
Offline KirkBurner
« Reply #3 on: July 17, 2014, 01:32:08 PM »
Came this far the other day,
I have been reading up on afew of the threads here, getting inspired...
Offline greenjeans
  • 1972 CB750K2
« Reply #4 on: July 17, 2014, 01:42:52 PM »
I think this is the best way to really learn the ins and outs of your CB.  The first motorcycle I ever had came just like yours.  I sorted through the parts,
picked the best looking of the parts and put it together following my trusty manual.
Good progress - at least with a roller, it looks like a motorcycle.  Keep it going.
Offline KirkBurner
« Reply #5 on: July 17, 2014, 02:26:00 PM »
Mr GreenJeans.. its my second... but this one is original..
I started to tread the wires through the handlebars today but forgot to take a picture
Offline Tews19
  • I am no
« Reply #6 on: July 17, 2014, 04:20:59 PM »
Subscribed and good luck on the build. Looks to be an early 750 with a unicorn triple tree.
1970 Honda CB750 survivor.
Offline KirkBurner
« Reply #7 on: July 21, 2014, 11:09:26 AM »
So today I put on the gauges... And rear fender...
I also found out that the cheap paint remover I got works wonders.. So it seems I can get this project done even cheaper
I am missing alot of bolts so.. Its slow getting there...
Offline edwardmorris
  • Youngish
« Reply #8 on: July 21, 2014, 11:16:23 AM »
There is a thread around here with a spreadsheet of all the hardware listed, see if you can find it, will come in handy...
Offline KirkBurner
« Reply #9 on: November 09, 2014, 02:17:42 AM »
Things slowed down abit.. and I am getting back into the groove..
I started to move into a new facility, with more people to hang out with in the garage.
I moved onto the engine... I have some rust issues with the crank bearings...
since this all came from cardboard boxes... I am missing afew parts here and there.... so one rebuild to check for all parts then .. a proper one....
Offline dhall57
« Reply #10 on: November 09, 2014, 04:38:35 AM »
Now that's the true meaning of a bike in a box ;D How did you find this assortment of goodies and how did you know it was all there to make a complete bike. Must of been a super deal for you to go that route. Good luck KB and I'll been watching this thread as you progress.
1970 CB750KO
1971 CB500KO-project bike
1973 CB350G- project bike
1974 CB750K4-project bike
1974 CB750K4
1976 CB750K6
1977 GL1000
1997 Harley Wideglide
« Reply #11 on: November 09, 2014, 09:38:40 AM »
What year did they call it? I see 72 headlight ears, 71 taillight, 73 or later motor....nice combination actually.
Offline MickB
« Reply #12 on: November 09, 2014, 10:05:16 AM »
Go Kirk, I bought a pallet load of parts with lots missing, but it's slowly turning into a bike.
Keep at it a little each day and you'll have a bike before you know it.
The blokes here are the brains trust, any questions will be answered.
You'll know the bike inside and out.
All the best.
Offline KirkBurner
« Reply #13 on: November 09, 2014, 10:39:22 AM »
The guy said he was making a k2, but then again.. I dont plan on making a period correct one as of now.
the Frame is a k2 ... new harness is a k2...  engine atleast the serial number is a 73 I think..
it was imported from Sweden to Norway in parts so.. I guss I will be missing afew.
I will be trying to update as much as possible here, cause I will have questions never done a lower end rebuild before
« Reply #14 on: November 10, 2014, 03:15:06 AM »
Subscribed.
Good luck!
Offline KirkBurner
« Reply #15 on: November 13, 2014, 03:17:59 AM »
I have slowly started to inspect the parts that i have... Finding alot of rust in parts of the engine and some wear on the gears... And there seems to be missing som bearing retainers...
Offline KirkBurner
« Reply #16 on: November 13, 2014, 12:52:34 PM »
Lucky me... I have been searching for weeks for one missing box with parts.... Now I may not have flesh out cash for all these parts....
Offline KirkBurner
« Reply #17 on: November 23, 2014, 11:52:34 AM »
So I have been going back and forth to the shop... and it seems I have managed to find almost all the parts that I need.
I feel the need to replace the golden parts, so there will have to be some shoping.
so to do something productive I honed the cylinders,
Hopefully within this week I will have gone to the machineshop to get some plasticgauge.
and the question is.. replace the rod connector bolts or not...
And I need to figure out a way to tackle a crank rod bearing that is rusted all away...
« Reply #18 on: November 24, 2014, 05:44:37 AM »
Please make sure that you have the correct size spacer washer in the tube clamp area on your upper tree so that fragile part does not crack, may be expensive to replace over there  ;)
Offline KirkBurner
« Reply #19 on: November 26, 2014, 01:30:14 PM »
today was plastigauge time...
main bearings and rod bearings..
they have some ugly wear and rust and disintegration ..
the spesification on the crankshaft was ABAAA 13333
Crank
                 1            2               3             4              5
lower     d7e std  d6e std     d7e std    d6e-a std     partially disintegrated
Top       d7e std                   d7e std    d7e std       d7e std
Clearing >0,05                    0,05           >0,05
Rods
             Low      high    clearance ... comment
1     d7h    d7d std      <0,038
2     d7j   d7h                <0,038    really worn
3     d7j   d7h              0,05       green bearing little wear marks
4     d7j   d7h              <0,038         worn
« Reply #20 on: November 26, 2014, 04:15:22 PM »
Is the journal. As bad looking as the bearing?
Offline KirkBurner
« Reply #21 on: November 26, 2014, 09:38:16 PM »
There is wear but not like the wear on the bearing... I doing this for the first time so feedback is nice
Offline MidnightLamp
  • Wrenchy wrenchy wrench!
« Reply #22 on: November 26, 2014, 10:07:22 PM »
Get it polished at an engine machine shop, get it mic'd and check to make sure it's within the allowance in the manual. The bearing grades/tolerances are pretty tight, not much room to take out gouges. That looks like an awful lot of scoring (but it's always difficult to judge that by pic).
'75 CB750 - Racer
'69 CB350 - Racer
'68 Enfield 350/440(flat top) - Steet
'54 Enfield 350 - Resto
'74 Commando 850 - Restomod
'67 Enfield 750 (TT7) - Resto
Offline KirkBurner
« Reply #23 on: December 11, 2014, 01:15:52 PM »
So I finely got around to the workshop...
I got these pictures after I cleaned it with the degreaser, so.. some polishing needs to be done or.. its time to source something new.
or.. I could go about and move the crank from my other bike, and get a racing one from Ape or Cyclex or something..
Offline MickB
« Reply #24 on: December 11, 2014, 03:44:36 PM »
Kirk good luck I know exactly what it's like as I got it all on a pallet, but by bit you'll get there.
Subscribed.
