Author Topic: '72 CB500 Throttle Cable Routing  (Read 2260 times)
Offline jmelche2
  • 1974 CB750K
« on: July 22, 2014, 03:43:23 PM »
I just replaced one of the throttle cables and I have managed to bugger up the routing.  The cables are too tight when turning right and I can feel it in the grip.  I think the cables ran under the left front rubber tank mount (when the tank is installed).  I appreciate any feedback.  Here are some pictures.  Thank you!
Offline goldarrow
  • one day, i'll be an
Re: '72 CB500 Throttle Cable Routing
« Reply #1 on: July 22, 2014, 03:47:50 PM »
should run along right side of the frame
CB550 K0
Offline jmelche2
  • 1974 CB750K
« Reply #2 on: July 22, 2014, 04:29:35 PM »
Ugh!  Must have been wrong all along.  Thank you.
Offline SohRon
« Reply #3 on: July 22, 2014, 05:35:52 PM »
Cables should run behind everything; brake hose, clutch cable, etc. Route them behind the wiring harness rather than in front of it as shown in the pic.
No, it's the clutch cable that runs along the right side frame; the throttle cables route to the left side, then through the coil opening.
« Last Edit: July 22, 2014, 06:02:19 PM by SohRon »
Offline ataylor136
« Reply #4 on: September 16, 2014, 07:23:09 PM »
Above or below the tank rubber?
Thanks for the info!
DH
« Reply #5 on: September 17, 2014, 07:51:18 AM »
http://www.sohc4.net/cb550books/
scroll down, click on "chassis wiring" last topic........cable routes under rubber cushion
