You can download shop manual from here:
http://forums.sohc4.net/index.php?topic=17788.0Never had Clymer, shop manual is usually better, but every manual I ever had in my hand and used - including T-55 in Russian language
- had mistakes and you still need to use your head to get it done.
Tools:
- ring compressor - I used hose clamp with edges sanded smooth, there are people who do it just with fingers
- cylinder gauge, inside dial gauge and micrometer - you can find it at Enco and/or Grizzly at decent price/quality
- alternator puller, hmm, somebody here makes them and sells them for decent price, but I am not sure now what you need for your bike. Often they are just big bolt with the correct thread, the shop manual should tell you, Clymer likely too.
You can always outsource measurements, local shop could check things for you. Sometimes it is the easier way, since using precision measuring instruments is a skill too and takes time to develop.
Understand, I am not trying to talk you into some adventure here, nobody but you knows your ability - did you ever wrench on something? Setting seat height on a bicycle is not really wrenching - even though technically you are using a wrench to do it
If you decide to do it, take your time, sort your parts - egg cartons, zip locks, containers, sharpie and labels, take pictures. It helps to have it laid out on a work table if you have the space.
Questions: take it one step at a time, ask questions relevant to what you are doing now, there is a lot of people here eager to help you succeed.
What to replace while it's torn down? My crystal ball is little foggy this morning
you will not know till you take it apart.
Good luck!
