Author Topic: cb550 grab bar questions  (Read 3536 times)
Offline Thamuz
« on: July 23, 2014, 03:36:38 PM »
I need 2 grab bars, a 74 cb550 and a 77 cb550f.  Do these have to be year specific or will this work across all years?  Im not going to resell the 550f.  the 74, maybe. lol  Original parts would be nice, but yeah
1979 Yami Chopper XS1100s
1978 CB750k
1977 CB550F
1974 CB550k
Parts bike for the 550's
Offline goldarrow
  • one day, i'll be an
Re: cb550 grab bar questions
« Reply #1 on: July 23, 2014, 03:45:56 PM »
if memory serves me right, mounting holes are the same locations.  rear end shape of the bars are different, and also blinkers mounting locations.  so yeah they varies throughout the years and between K and F
CB550 K0
Offline Thamuz
« Reply #2 on: July 23, 2014, 04:13:19 PM »
76 cb550k should work on a 74 cb550k?  that one has nothing on back.
1978 CB750k
1977 CB550F
1974 CB550k
Offline goldarrow
« Reply #3 on: July 23, 2014, 05:20:28 PM »
74 has different blinker mounting holes.  74 blinkers are smaller than 75/76
CB550 K0
« Reply #4 on: July 23, 2014, 05:50:21 PM »
The Cb550 F models use a grab bar that matches the seat rear "turn-up" profile.  All years of F 75-77 are interchangeable.  These are different than ALL K models.  But, you might be able to mash together something that works/functions, even though it is not a correct match.
I believe the 74 will take a grab bar from a 72-73 CB500, as well as from 75-76 Cb550K.  I have not verified the part numbers of all.  Yes, the turn sigs are different from 75 on, but the mounting tabs on the bar itself is the same, as I recall.
Avoid the 77-78 Cb550 K grab bars. I'm pretty sure they will hit the tail lamp mount.
Offline goldarrow
« Reply #5 on: July 23, 2014, 06:23:53 PM »
The tabs have different mounting holes sizes to accommodate larger or smaller blinkers
CB550 K0
« Reply #6 on: July 23, 2014, 07:00:33 PM »
The tabs, or the brackets and rubber pieces that go on the tabs?
Offline Thamuz
« Reply #7 on: July 23, 2014, 07:03:27 PM »
So, to put it right, a F is a F.  the K is all over the place?  If that's the case, I am gonna take the 3 piece grab bar and have it welded back together. >.<
1978 CB750k
1977 CB550F
1974 CB550k
Offline goldarrow
« Reply #8 on: July 23, 2014, 07:10:51 PM »
Here's off 75/76 550k
This one 74 550k. Smaller blinker with smaller peg and will surely be smaller hole and different rubber pieces
CB550 K0
Offline Thamuz
« Reply #9 on: July 23, 2014, 07:38:32 PM »
Ty gold.  visual is best.  I been lookin on fleabay too.
1978 CB750k
1977 CB550F
1974 CB550k
Offline SohRon
« Reply #10 on: July 23, 2014, 08:46:38 PM »
That '74 is missing a couple of parts... Here's the bar with its mounting hardware, then a shot of it on the bike
« Last Edit: July 23, 2014, 08:50:28 PM by SohRon »
« Reply #11 on: July 24, 2014, 09:28:30 AM »
You can fit both the old and new blinker stalks on any of the 72-73 CB500s and the 74-76 CB550s grab bars if you have the correct parts to mount them.  Goldarrow's posted picture of the 74 is a field modified hack fitment, missing the vibration isolation parts.
Offline goldarrow
« Reply #12 on: July 24, 2014, 09:35:35 AM »
Yes indeed mine is missing few parts by the PO. But if I remembered correctly holes to fit the blinker stalks are different sizes
CB550 K0
« Reply #13 on: July 24, 2014, 09:54:03 AM »
So, I waded out into my cluttered storage shed/garage.  Indeed the tabs are different for mounting the newer 75-76 blinker stalks.  If that is an important consideration, then only the grab bars from 72-74 K models will be period correct.  But blinker tabs notwithstanding, the actual grab bar profile to surround the seat is the same for 72-76 K models.
Offline goldarrow
« Reply #14 on: July 24, 2014, 09:58:17 AM »
For OP, this may not be crucial info, but for future readers this info maybe important info.
CB550 K0
Offline Thamuz
« Reply #15 on: July 24, 2014, 01:08:39 PM »
It is to me.  Trying for a good resto of the 74
The main issue it seems is finding a F grab bar.  K all over.  no way to make it work?  It is just the angle difference?
1978 CB750k
1977 CB550F
1974 CB550k
