Author Topic: Kerby Honda . . .  (Read 590 times)
Offline Doc.
Kerby Honda . . .
« on: July 26, 2014, 09:16:43 AM »
Hi.
Found the site while looking for info on the Kerby Hondas.
A new friend of mine has one, and has offered me a ride on it at the Belgium Classic TT at Gedinne, end of August.
Not me on it, not ridden it yet, taking it to Bedford Autodrome on the 9th for a Track-Day, needs a little 'tweaking'.
Any other owners/riders here, or anyone with a bit of knowledge of them?
Cheers.
Doc out . . .
A Pessimist is just an Optimist, with experience.
Offline Tim2005
Re: Kerby Honda . . .
« Reply #1 on: July 26, 2014, 11:30:17 AM »
They are among the rarest of all the frame kits.  These couple of  threads might help a little....
http://forums.sohc4.net/index.php?topic=68470.0
http://forums.sohc4.net/index.php?topic=110960.0
Offline Doc.
Kerby Honda . . .
« Reply #2 on: July 27, 2014, 03:47:31 AM »
Thanks Tim, hadn't seen that second topic.
Not a lot of info about, must be rarer than I first thought.
I feel quite privileged to be working on it, let-alone riding it  8)
Stripped it down to the Frame and Engine yesterday, to prep it for the Trackday on the 9th.
Doesn't need much doing, just wanted to check it all over after finding some missing screws, quite a few non-locked Nuts & Bolts, and a couple of incorrectly fitted/adjusted parts.
Can post pics if anyone's interested . . . I realise it's not a SOHC  ;)
Doc out . . .
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #3 on: July 29, 2014, 07:56:50 AM »
Doc (and Tim)
You might find some more info from the guys on www.sohc.co.uk
Use the same username so that we recognise you...
Steve
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline Doc.
Kerby Honda . . . and 750 OHC
« Reply #4 on: August 10, 2014, 08:05:20 AM »
Well, Trackday didn't happen for the Kerby, clutch was slipping when it was on the Dyno a couple of days ago, so the owner wanted to get that sorted first.
We did go though, and took his OHC 750 . . .
Perfect day for it, pity it had an oil leak that stopped play   :'(
Went out in the first session, and was impressed with how well it went.
I've never ridden it before, and hadn't been on track for a few years, so took it fairly gently (luckily).
First three laps were 'sighting' laps, following a staff member.
Just after he pulled off, I felt my left Boot slipping on the peg, looked down to see Oil all over it.
Pulled in to check it over.
Looked to be coming from the bottom of the gear-change cover, so we whipped it off and found the gasket was broken at the rear lower corner.
As we didn't have a spare, we refitted it with some blue Hylomar, wiped the oil off the rear tyre, and I went out again.
Kept an eye on it, and after four laps or so it was doing it again.
Pulled in and whipped the Crank cover off.
Gasket was fine, as was the surface of the Crankcase.
Then I looked at the inside of the Cover itself, and there was the cause.
It's not got an Alternator fitted, and the gap in the casing where there should be a rubber bung (where the loom passes through), was just empty, no wonder it leaked!
It's sitting in the workshop now, as in the pictures.
What a palaver getting the front wheel out, horrible design, having to remove the Caliper mounts is a real b**l-ache, any 'tips/tricks' for that?
Can you, for example, slot the top pivot mounts so the two bolts don't have to be removed, just loosened?
Cheers!
Doc out . . .
« Reply #5 on: August 10, 2014, 09:16:57 AM »
Nice looking bike Doc.
Couple things? Is that piece over the end of the crank just a cap to block the oil flow from the crank or does it serve another purpose?
Don't understand the front wheel issue? Did it not just drop off after you removed the fork caps on the bottom?
Offline Doc.
Kerby Honda . . .
« Reply #6 on: August 10, 2014, 01:30:01 PM »
Thanks.
It got more attention than all the GSXRs/R1s/CBRs/ZXRs etc.
Lots of Riders stopped to look as they walked passed, almost all of them smiled approvingly.
That piece is just a cover (the original one, but modified).
The crank is standard, and the Bike still uses the starter motor.
There's a machined Alloy 'cap' on the end of the crank, I presume to retain the starter gear/clutch, and the cover is shaped to cover it closely.
No, the Tyre is too wide to pass through between the two Caliper pivot assemblies.
Might do with just one side removed, but I wanted them both off to check for wear anyway, and the owner wants the bolts drilled for lock-wire.
Even removing one side will be a pain though . . .  :o
« Last Edit: August 10, 2014, 01:35:55 PM by Doc. »
Doc out . . .
