Author Topic: CB750 Shifting Quality - K4 How Do You Rate It?  (Read 2422 times)
Offline RRRToolSolutions
  • I love old Japanese bikes!
« on: September 24, 2006, 02:16:34 PM »
Well, I'm gonna have to strip the frame and pull the engine on my new 836. I get told this morning that I should have used sealer on the rubber plugs/disc under the cam towers .... :) :)
Anyway to the question - my 74 CB750 does not shift smoothly. It's notchy, there are false neutrals between gears. If I shift deliberately and move the lever through it's full travel, then it goes up and down the gears fine. If I get the least bit lazy, then it will occassionly miss the next gear. My CB500 has the same problem and it's a 6,000 origninal. This 750 has 9,000. Is this a feature Honda threw in at no extra charge?
While it's out, I thought I might have a look at the shifting quality. Everything in this transmission looked fantastic when tore down. As mentioned, it's a 9,000 mile bike that sat for several years with a crankcase full of oil. I checked the dogs, forks, shiftdrum, ratchet arm, replaced the return spring with NOS, and finally added assembly lube to the shift fork locators during testing while the case was open. All good, solid, positive shifts on the bench. i use only Motul 10/40 syntetic motorcycle specific oil in all bikes (buy it by the case). I've just changed the oil after 200 miles so I could tighten the oil cooler adapter and install the chrome K&N filter, but the shifting is still what I call "notchy".
Input appreciated. Thanks, Gordon
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
USN20
Re: CB750 Shifting Quality - K4 How Do You Rate It?
« Reply #1 on: September 24, 2006, 04:43:50 PM »
Sounds like you were quite thorough with inspecting the transmission, but you didn't mention the clutch which can sometimes contribute to shifting woes. My K4 is bone stock and I run regular Castrol GTX 10W-40 and shifts just fine. Sometimes I think it shifts too easily even with my lazy foot and it's adjusted by the book.
Clutch adjusted correctly and not dragging?
Clutch plates / springs aftermarket or modified?
Clutch inspected for correct assembly / mismatched or worn parts?
Because your transmission shifts well on the bench, I would look into the clutch or perhaps even try a different oil for a shifting evaluation.
http://www.castrol.com/castrol/genericarticle.do?categoryId=82915464&contentId=6003410
« Reply #2 on: September 24, 2006, 06:27:13 PM »
Barnett fiber disc and performance springs. The springs won't be an issue, but I'm not sure about the fibers.
Offline Loudpipe
  • Broken Vehicle Collector
« Reply #3 on: September 24, 2006, 08:13:50 PM »
My Supersport will occasionally slip into a false neutral if I get exceedingly lazy. I've never ridden a bike, including new ones, whose shifter wasn't a bit nochy. Unless your missing gears regularly or it very hard to shift, I would think it's alright.
- LP
1974 Honda CB350F
Previous: 1978 Honda CB750F, 1971 Honda CB500K, 2009 Yamaha YZF-R1
jymmeye
« Reply #4 on: September 25, 2006, 12:04:36 PM »
The DOHC guys have a fix for this which involves opening the shift spindle window a little bit.   Has anyone ever given this a try on a SOHC?
Offline dusterdude
« Reply #5 on: September 25, 2006, 01:58:21 PM »
if you try hard enough you can get false neutrals on almost any bike
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Loudpipe
« Reply #6 on: September 25, 2006, 07:23:10 PM »
Yep.  It's inherent in the design of motorcycle gearboxes.
- LP
1974 Honda CB350F
Offline SohcCBs
  • 76 CB836F 77 GL1000
« Reply #7 on: September 25, 2006, 09:49:58 PM »
You can adjust the shifting tension, I did......
http://www.salocal.com/sohc/tech/tranny/slipgear.htm
