Author Topic: 1972 CB750K2 (start from scratch) project. Cases back together  (Read 100702 times)
Offline Davez134
Re: 1972 CB750K2 (start from scratch) project. Small leak!!! Damn!
« Reply #175 on: January 26, 2015, 07:23:55 PM »
Do the nonos have chambers or straight through? I've been considering that option too after reading around here. Many seem to love the 300s for an agressive street 836...
They are straight through. Tried to get it in this pic, but hard to capture.
Offline Davez134
« Reply #176 on: January 26, 2015, 07:28:17 PM »
Those are nice! Can you also post pics of the other sides of pipes? Would like to see The chamber welding spots
Not sure if these are what you wanted. If not let me know
Have drain holes in bottom as well
Offline edwardmorris
  • Youngish
« Reply #177 on: January 26, 2015, 07:57:42 PM »
Thanks! So these ARE the 300 styled with removable baffles, very nice!
Offline Bill/BentON Racing
    • BentON Racing
« Reply #178 on: January 28, 2015, 06:24:44 AM »
Only if they come with that gorgeous wheel attached?  ;)
Dave, real nice! Cal I got one like that for sale ......for the rt price! D.I.D. 250x18 Buchanan's spokes SS H/D Gold anodized, Bill
BentON Racing Website
BentON Racing Facebook
Offline calj737
  • I refuse...
« Reply #179 on: January 28, 2015, 09:24:56 AM »
Dang, Bill, then I'd have to start another whole new build... ::)
Offline Davez134
« Reply #180 on: January 29, 2015, 01:42:42 PM »
Got my replacement oil pump rebuilt. New oil stopper seal/spring, new shaft seal, new case o-rings, new gasket. Clearances checked .16mm between rotors and nearly same between rotor/body. So I can rest easy now. This is what rotors looked like in my pump that i replaced. No wonder it didn't feel smooth
Now all good to go...
« Last Edit: January 29, 2015, 01:44:44 PM by Davez134 »
Offline Davez134
« Reply #181 on: February 04, 2015, 05:03:45 PM »
No real big updates, just waiting for a couple brackets, front brake caliper to show up so I can get powder coated then start assembly.
I needed some exhaust spigots, and found these made out of stainless steel. Cheaper than original replacements and no rust worries
Offline timbo750
« Reply #182 on: February 05, 2015, 12:19:36 AM »
Dave where did you get them. They look great, are there any more available?
Offline bert96
  • past ride
« Reply #183 on: February 05, 2015, 02:02:11 AM »
Would like to know too.
Bert
QA50 1969,ST-90 1974,mb5 1982,rz350 1983,shadow 1100 1985,vf1000f 1985,BMW K1 1990,shadow tourer 1100 2001,vfr 750 1994,vtr250 199?
Offline Davez134
« Reply #184 on: February 05, 2015, 07:30:12 AM »
I got them from a seller on ebay. Contacted him before buying, said he was going to try and gauge interest and make more if there was a need. They look great, but unfortunately the dimensions are just a bit off. The length from the bottom of flange to end of spigot that presses against gasket is about 2.5-3mm too short, so it will for sure have an exhaust leak. Also the diameter where pipe slides on is just a bit off as well. I contacted him about this and waiting for a reply back. We'll see what happens.
Offline Davez134
« Reply #185 on: February 05, 2015, 11:24:22 AM »
Seller refunded my money, said he is going to work on another set based off measurements I gave him. Stand up guy.
Offline timbo750
« Reply #186 on: February 05, 2015, 12:12:42 PM »
You might want to tell him also that there are others interested.  Maybe he should join the forum and put an ad in the classified section.
Offline Davez134
« Reply #187 on: February 05, 2015, 12:19:24 PM »
Yeah I told him about the forum. Said he wants to get it right first, but I told him there is definitely an interest.
Offline Davez134
« Reply #188 on: February 06, 2015, 06:28:33 AM »
Well, I think I successfully saved these.
Rust removed:
High temp paint to stop further rust:
Offline Davez134
« Reply #189 on: February 06, 2015, 08:45:52 AM »
This is done too. I wish I took a "before" pic
Offline Restoration Fan
  • My wife will never call me
« Reply #190 on: February 06, 2015, 11:50:13 AM »
That's gorgeous!
Did you paint that or use something like Mother's Back to Black?
Offline Davez134
« Reply #191 on: February 06, 2015, 12:14:40 PM »
Tried back to black, wasn't working so well cause the surface wasn't worn evenly, so there were dark spots. Ended up painting with rust-oleum black plastic paint, used plastic "adhesion promoter" spray after prep and just befor paint.
« Last Edit: February 06, 2015, 12:16:52 PM by Davez134 »
Offline Davez134
« Reply #192 on: February 11, 2015, 09:19:10 AM »
Carbs done!!! Love to hate these things
Offline Davez134
« Reply #193 on: February 13, 2015, 03:25:39 PM »
I finally got the front caliper I've been waiting for, but this insert is on the wrong side! Been searching for info on how to get it out, but no luck. If I cant get this thing out im gonna lose it
« Last Edit: February 13, 2015, 04:09:53 PM by Davez134 »
Offline Davez134
« Reply #194 on: February 13, 2015, 04:42:23 PM »
So It wont come out and now is deformed after many attempts and different methods. seems to be rusted solidly in there. I'm done. Off to ebay to find a reproduction body.
Offline timbo750
« Reply #195 on: February 13, 2015, 04:55:20 PM »
There are 2 ways to get it out.  What worked for me was a screw into insert and pulling it out.  The other that I have read about is cutting a nail with a flat head down to length so you can insert from within the caliper and then pull it out.  I would also try some heat - just enough so you need to use a glove to hold it as the aluminum will expand quicker than the steel insert.
Offline Davez134
« Reply #196 on: February 13, 2015, 05:01:43 PM »
Thanks man, I tried all those, including heat, PB blaster, letting cool, heat again. It was so stuck/corroded in there. Its deformed now, so I'm going to try and find another insert (good luck) and if not, just buy a repro caliper. I want to get on with my project.
Offline Davez134
« Reply #197 on: February 14, 2015, 01:27:18 PM »
Moved on from the caliper to other things today. I got front forks all done. I emailed progressive about using the spacers with their spring kit, and I think I got it figured out. I guess the final adjustment will be made after first few rides, but Here is what I have for now. I set fork oil level at 175mm. I put springs in, washer on top of spring, then cut the PVC spacer to 20mm. I'm about 175 pounds.
Offline Davez134
« Reply #198 on: February 17, 2015, 03:05:04 PM »
It's weird that everything brake related that can go wrong, has. Finally something right. While I'm still trying to repair front caliper, I got this done. Was going to paint, but decided to polish to match my forks. New o rings, polished pin too. Moves so smooth!
« Last Edit: February 17, 2015, 03:20:40 PM by Davez134 »
  • Youngish
« Reply #199 on: February 17, 2015, 03:33:51 PM »
Cool. What size o-rings are you using? IIRC these were NLA and the next size up was too big. I ended up getting Acura Fuel Injector o-rings from a Japanese seller for this. They are the exact same size as OE.
