Author Topic: 1972 CB750K2 (start from scratch) project. Cases back together  (Read 102439 times)
Offline Davez134
That's great, thanks!
Offline Davez134
I decided to mess with a tach I had before the ones from Steve-o arrive so I don't mess anything up. Managed to get it apart fairly easily. The damper pot was empty, but looks easy to refill. Everything else cleaned up nicely.
Have to be very careful with the spring, make sure to support it and move as little as possible. I ordered some rc car diff fluid as well as some white lithium grease for the speedo when it gets here.
« Last Edit: October 16, 2015, 03:18:39 PM by Davez134 »
Offline edwardmorris
  • Youngish
I thought the later style ones didn't use damper fluid and had magnetic bases? OCICBW.
Offline Davez134
Just to be clear, I have no idea what year this tach was from ;) I know it is later than K2. I just posted up some pictures so others could have some reference if the inside of their tach looks like this.
Offline Davez134
Got the gauges in the mail today. Thanks Stev-o!!! Started disassembly, and step 1 complete in less than 15 minutes. Set mileage to 2000, what my bike has on it.
No way to remove damper pot on this tach, so they are different.
Rough looking, but function, and mechanism is clean! Just needs some lubrication and cosmetics now!
« Last Edit: October 18, 2015, 07:16:05 AM by Davez134 »
You're welcome, Davez.  Looking forward to seeing what you can do with these.
Maybe this is your calling, we need someone who can restore these?!
  • Youngish
Yea those are late K2/early K3 style ones. Little lube is all they take to work well.
Stev-O Marcel is probably the best guy to do these perfectly right. His SS rings aren't easy to crimp without proper tools which I don't think anyone but Marcel has. For my K2, I had help from Jerry H who had already done his K2 set pretty nicely. Even he mentioned the new SS ones were tough. For my K3, I simply polished up and reused the old ones and was able to do a modest job myself ;)
I'm aware of Marcel, he restoration work is excellent.  But his services are expensive and shipping to Europe is not cheap.
Take my Kaw 500 H1 gauges for example.  There is a Triples forum member in FL that totally [mech & cosmetic] restores them for $100 a gauge, just had mine done. Too bad he wont do Honda gauges.
Offline Davez134
For restoration Marcel's parts are amazing quality if your pieces are too far gone, no question there. My goal here is to take LOTS of pictures and explain everything I run into in detail to show people who want to give it a try that it's not that hard. This is my first time diving into them, but with an eye for detail and some patience, I'm sure anyone can do it. As far as offering a service, I have my first kid on the way in about a month so I don't think I'll be able to commit time haha!
« Last Edit: October 18, 2015, 11:38:00 AM by Davez134 »
Offline Davez134
Got rid of some rust and painted with primer. Filled tach damper pot, lubed with lithium grease, tested on bike,. It is so smooth! Still waiting on faceplates from cb750faces,  then I can get these put back together.
Offline Davez134
I see what you mean now about the shipping. I know it has nothing to do with the vendor, as he shipped within a couple days, but geez it takes a while. I'm sure US customs has some part in the delay too. Hopefully will be here before the weekend.
How long has it been?
Offline Davez134
Ordered 10/13 (and just to be clear, not complaining. Quality stuff is worth waiting for)
« Last Edit: October 29, 2015, 11:49:45 AM by Davez134 »
Offline Davez134
So I finished these up today. I will take better pics tomorrow in good light. Crimping those rings back kicked my butt!
Had to drill for reset knob. 7/32 on my stepped drill bit came out perfect
Great job, Dave. They look like new.
Offline Davez134
Thanks again Stev-o, much easier to take apart gifted parts! Even better than looking new, they work great too! Finally have good gauges. Hopefully these pictures will help someone else out when searching for this stuff. And, thanks Marcel for offering great resto products!
Glad it worked out for you.
When I first saw your bike I thought "He's not going to want to put those crap gauges on that beautiful bike!"
Offline Davez134
Not the most exciting update, but I added oil pressure gauge for peace of mind. I meant to do this a while ago but spaced it out. It was sooo easy to install. I may leave it on, or just use to check pressure periodically.  Looks OK too, just have to get used to it if I leave on.
  • Youngish
Re: 1972 CB750K2 (start from scratch) project.
« Reply #470 on: February 12, 2016, 04:35:06 PM »
Very nice! Same one is going on my K3. Be sure to carry the old galley cover in the tool tray just for the worst case that it breaks and you need to plug it up to ride back home.
Offline Davez134
« Reply #471 on: February 12, 2016, 06:43:43 PM »
Damn that is a great point! I just went and put it in my tool pouch thanks!
  • Youngish
« Reply #472 on: February 12, 2016, 07:51:46 PM »
Not my idea, Frank/754 posted it somewhere and I just remembered  ;)
Offline Davez134
« Reply #473 on: February 18, 2016, 06:20:59 PM »
Pulled out pump because although pressure was ok, I was wet sumping after every ride. Oil stopper looks to be good with no damage, but going to replace that and all o-rings around the 3 collars and a new screen while I'm at it.
Was pleased to see my oil pan looked like this after 2700 miles on new engine
Offline Davez134
« Reply #474 on: April 26, 2016, 08:50:43 PM »
And... My final small oil leak is getting on my nerves now. Small leak from final drive shaft seal is making the rear wheel nasty. Started removal today, installing tomorrow
