Author Topic: CB400 four clutch drag  (Read 585 times)
Offline blueflames57
« on: July 29, 2014, 03:17:01 PM »
Hi, I have 1975 CB400 four, the clutch was slipping so I decided to fit new friction plates, other than slipping the clutch action was light and neutral selection was easy, having fitted the plates I can not get the clutch to adjust properly, the action is heavy and does not feel right neutral selection is difficult/near impossible its got to be something I have done wrong but I can't figure out what, can anyone help. Thanks
Offline Chris71
Re: CB400 four clutch drag
« Reply #1 on: July 30, 2014, 03:36:58 AM »
What type of oil did you put back in was it the same grade/type? Are you ajusting the clutch at the cover or only on the lever?
« Reply #2 on: July 30, 2014, 12:34:47 PM »
I had got this problem too. Clutch did not work at all. I thought I had made a msitake when mounting the new fibver plates. Checked and found OK. I had to rock the bike forwards- backwards some times on 2:nd gear to make the clucth to work.
Then problem with finding neautral when hot.
OIL...
I used Castrol 4T Act Evo 20W-40 for the first 500km's break-in. Horrible clutch glue.
Castrol 4T Act Evo 20W-50.... Additional Zinc (ZDDP) helped some. Finding neutral easier but still dragging clutch when cold. (When not used fo a day or 2)
I have got new oil today, Red Line motor cycle oil 20W-50 and additional bottle of 20W-60. I hope this will solve the clutch issues when oil is of best type of synthetic with plenty of zinc + phosphorous in it.
Back in the days (79-90) I never had clutch issues like this. Cheap car oils, Quaker State single grade, Hance & Vines oil, Castrol GTX 2 and 3 car oils, Mobile One car oil. The last one caused some slip when gearing to 5:th at 190km/h and max throttle.
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=6pf1fupvet4nvjpuasvp5clio7&/topic,60973.0.html
« Reply #3 on: July 30, 2014, 12:43:08 PM »
is the pressure plate korrekt placed..it fits only 2 of 4.. possibel posisions..as i renember
i hate all this v-w.... vords
