Author Topic: Fork Seal Removal 78' 750F  (Read 639 times)
Offline Zax
« on: July 30, 2014, 08:57:20 AM »
Hi,
 I am hoping some one can look at the pic and tell me if the metal portion that I have beat up pretty badly is part of the fork seal or the fork leg. The searching I have done has not helped me much. I am hoping that is it part of the fork seal and is just rusted to the fork leg itself after the 20 odd years it sat. My concern is that seals i got from the dealership look very little like the seal that is in there currently.
Thanks,
Zach
1978 CB750F
Offline 78whiteorbs
Re: Fork Seal Removal 78' 750F
« Reply #1 on: July 30, 2014, 09:32:51 AM »
Yep,looks like the seal to me. Boil that leg in a pot of water the try and grab that protrusion with some needle noae vice grips and twist towards the center. If marred to bad I have two perfwct legs I would let go cheap....
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=41o643ls520r1gllom65glb0v5&/topic,60973.0.html
« Reply #2 on: July 30, 2014, 09:35:15 AM »
yes heat vill loosen it up..specily if some lockteit are used to seal ekstra up..
i hate all this v-w.... vords
Offline Zax
« Reply #3 on: July 30, 2014, 10:15:07 AM »
Thanks guys, heat it is!
Zach
1978 CB750F
« Reply #4 on: July 30, 2014, 11:33:14 AM »
I used a cheap heat gun that made it easier. This tool is really useful.
- Which kind of seals will you use? Same as CB750 k6?
The low 11mm seals are crap. My leaked direct.  CycleX version. I ordered HONDA OEM from Germany that look similar.
I got much better ones from David Silver that sell the thicker version. Huge difference when this model is more rigid as well. Same type I used +30 years ago. No doubts how to mount it eaither
See this link where I wrote my experience after I here found out which to use.
http://forums.sohc4.net/index.php?topic=131619.0
