Author Topic: Neutral switch wire route  (Read 3405 times)
Offline Paul Lowe
  • If you like then it is good...
« on: July 31, 2014, 12:44:48 AM »
I am restoring a K1 750 and the neutral wire was broken. I have repaired the switch and found the wire from the harness however it's not clear the route down to the switch. There doesn't seem to be an obvious one after checking all the manuals I have.
Can anyone describe the path of this wire or provide a pic please?
My best guess is that it goes through the gear shift cover on left side and pops out underneath?
Sorry if this is a dumb question!
My Honda sickness deepens
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
1/2HP electric bike home made...
Online PeWe
Re: Neutral switch wire route
« Reply #1 on: July 31, 2014, 02:54:56 AM »
I have found this photo in a CB750 restore project. I connected this way (not the short cut beside the gear selector)
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
« Reply #2 on: July 31, 2014, 03:55:56 AM »
+6
That's how all of mine are routed. The photo is from underneath and the wire is routed up through the sprocket well. This wire typically remains well lubed. Near the top there originally would have been another fold-over tab to help hold the wire away from the sprocket. It would not be visible in this photo but would be near the top left of the picture.
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline Paul Lowe
« Reply #3 on: July 31, 2014, 04:02:04 AM »
Thanks. I think if I make tabs that looks like a plan!  Is that the way they came from the factory?
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
Online PeWe
« Reply #4 on: July 31, 2014, 01:40:19 PM »
Another photo of the same restore I found here or another site. (I saved some photos that show all tabs for wires on engine. Neutral and ignition wires.)
« Last Edit: July 31, 2014, 01:43:01 PM by PeWe »
Offline Paul Lowe
« Reply #5 on: August 01, 2014, 11:44:48 PM »
Thanks everyone got it sorted now!
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
