Author Topic: 1978 CB550k Keihin PD carbs Parts needed  (Read 555 times)
Offline Passpawn
« on: July 31, 2014, 01:01:52 PM »
Hello,
I am trying to replace the rubber bushings in the upper and lower throttle rods. The upper has the flat style rubber bushings and the lower has a small oring. When I disassembled them, I noticed the upper bushings on the ends of the rack are not rubber, they are cardboard/cork/etc. I was at a Honda dealer and they said these items only come with the complete carb assembly. Does anyone know if I could use a metric oring in the upper?
Looks for guidance on where I can purchase new bushings and orings for all four carbs.
Thank you!
Offline RevDoc
Re: 1978 CB550k Keihin PD carbs Parts needed
« Reply #1 on: July 31, 2014, 01:31:43 PM »
Contact forum member James at harisuluv. He's a wizard and will be able to help you out!
http://forums.sohc4.net/index.php?topic=115539.0
Dana
'78 CB550K--Angie
'82 CB750 Custom--Eva
As soon as you straddle a bike expect every other driver on the road to suddenly start competeing for the title "Dumbestsonofa#$%*inallNorthAmerica!!"
Offline FillionJ
« Reply #2 on: August 01, 2014, 08:16:10 AM »
I purchased a set of carbs on eBay off a 78 550k so I could replace a carb from my 77 550k they are all apart but when I get home I'll have a look I could always pack em into a box n ship em off.
