Author Topic: Will a 4 into 1 pipe from a 75 cb400F fit on a 73cb500K?  (Read 591 times)
Offline tennesseebreeze
  • Better to be lucky than smart.
« on: August 01, 2014, 05:12:37 am »
I want to do a 4 into 1 pipe for my 73 cb500 build and I have a chance to have one sent to me from a 75 cb400 super sport. He says the spread of the four pipes are adjustable, but will it clear the frame?
« Last Edit: August 01, 2014, 07:34:32 am by tennesseebreeze »
'79 CB750F, '73 CB500K2, '78 CB400A, '71 CL100
Offline thep1pe
  • Proud Owner 76 CB550F1
Re: Will a 4 into 4 pipe from a 75 cb400F fit on a 73cb500K?
« Reply #1 on: August 01, 2014, 06:52:43 am »
75 400 has a 4 into 1
Offline thep1pe
« Reply #2 on: August 01, 2014, 07:08:36 am »
You should change your post title if you want an answer.
I think it is unlikely to fit as the 500 has a duplex frame, the 400 does not. So not much room for header pipes. But what do I know I've never done that myself.
« Last Edit: August 01, 2014, 07:16:23 am by thep1pe »
« Reply #3 on: August 01, 2014, 07:24:16 am »
I realized my mistake and posted it.
Offline MoMo
  • Ride like you're invisible
Re: Will a 4 into 1 pipe from a 75 cb400F fit on a 73cb500K?
« Reply #4 on: August 01, 2014, 08:23:17 am »
highly unlikely, the spread may technically be called adjustable but it is not as it has the headers have to go into specific locations in the  collector
