Author Topic: cam chain adjustment screw oil leak  (Read 958 times)
Offline zenocchio
« on: August 01, 2014, 03:24:10 PM »
I almost changed all the gaskets and o-rings in my engine now.
I believe I developed a leak from the cam chain screw, and looking at the fiche i see an O-ring between the head and the washer and nut.
My question is, can I loosen that nut all the way to replace the o-ring without the risk of loosing the tensioner screw?
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=42o45f8a3mv9foo1be9c5l54a7&/topic,60973.0.html
Re: cam chain adjustment screw oil leak
« Reply #1 on: August 02, 2014, 01:49:28 PM »
if it are a 500/550 you can..but the threds can be bad..so it not easy can be turned aut...there must not be used force/power..it can breake tensinone adjusting..so a schrevdriver must be hold so it not turns the senter part..so only the autrunner schrev turns off
vhy not loosen the bolt...vash it in fuel.and give it a bit floting gasket..and make the cam chain adjusting as the book rekamendes..and it vill be nice tight ,
« Last Edit: August 02, 2014, 01:52:08 PM by strynboen »
i hate all this v-w.... vords
