Author Topic: CB550 Electronic Ignition  (Read 16102 times)
elcid
« on: March 30, 2005, 12:07:35 AM »
I have a 75 Honda cb550 & would like to install electronic ingnition. I "hear" that it would improve my bike's performance in the starting department. BUT my mechanic says it would make no difference. I tend to think he is annoyed with working on an old beater like mine & would rather sell me another one of HIS old beaters!
So is there a noticeable difference? Is it worth it? It seems my points ALWAYS need to be readjusted or replaced. Why do they go out of whack so much?
Also where is the best place on the net to buy them cheap. Anywhere that shows how to install as well? I really don't want to get rid of me old steel dragon yet. She's reliable!
Thank you
Offline Flood
Re: CB550 Electronic Ignition
« Reply #1 on: March 30, 2005, 12:53:56 AM »
I'm still on my old points with my bikes, but I have installed an electronic ignition in my car. I don't think you will notice an increase in performance or responsiveness.
The point ignition was used in Honda's GP bikes of the 60's and the 250 6-cylinder rev'ed up to 12.000 and more!
The main reason to upgrade is that you don't have to readjust all the time. But that's surely a good reason. It'll make your dragon even more reliable.
Cheers, Remi
Ibsen
« Reply #2 on: March 30, 2005, 01:35:47 AM »
Like mentioned, there will be the advantage of: install it, adjust it and forget it.
Your bike will be easier to start, and it will run slightly better. Also the fuel economy will increase a litttle bit.
Once it is installed and adjusted properly, you will never regret it.
Dyna, Boyer Bransden and Newtronic, all produce systems.
Boyer and Newtronic are making systems that can be used with your old coils. If you buy a Dyna system, it is recommended that you buy Dyna high performance coils.
http://www.dynaonline.com/english/
http://www.newtronic.co.uk/
Boyer Bransden do not have a website, so you will have to find a reseller, such as:
http://www.motorcycle-parts.com.au/Boyer_Bransden.htm
« Last Edit: January 10, 2006, 04:28:12 PM by Glenn Stauffer »
Sandcast 2356
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #4 on: March 30, 2005, 04:02:52 AM »
Notwithstanding the comments made on the link attached by Sand, I've found the "fit and forget" nature of electronic ignition to be well worth it.
Boyer Bransden (UK) can be reached at +44-1622-730939 (Maidstone Kent), they don't appear to have a website.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Ibsen
« Reply #5 on: March 30, 2005, 04:29:06 AM »
I have had a Boyer Bransden Mark III system on my Kawasaki twin for 9 years and 35 000 miles. It has worked faultless ever since I installed it, and I have no problem recommending it.
And the reason I bought the system was that there was no dealer in Norway that could supply new points for that bike, but one of them offered me the Boyer system for a good price.
That was before I learned that my Kawa twin share it's points with the CB750 :D
But nevertheless, I'm glad I bought the Boyer system. :)
Offline cben750f0
« Reply #6 on: March 30, 2005, 04:41:25 AM »
am running the Dyna 'S'... and it starts better, and revs cleaner, in the upper rev range.... though i cant see and difference in the fuel economy..... fit it and forget it.... good money spent...
AndreRA3
« Reply #7 on: March 30, 2005, 09:25:53 AM »
I have a Dyna-s and Accel 3ohm coils on my CB750, and it runs a lot better than it did before.  Sure, maybe it's because the old coils were toast, but the bike starts on  the first kick every time, and midrange hesitation has been greatly reduced.  No, it wont solve all your problems, but it surely masked a few on my bike  ;D .  It might be harder on your battery than points, but I can't compare mine to the points, since my electrical system has been problematic since I bought the bike.
« Reply #8 on: March 30, 2005, 09:27:20 PM »
I've never owned a 550, but I've been fitting either Martek 440 (sadly not made any more, but if you can find one, it'll probably work fine) or Dyna S/Dyna 3 ignitions to my Cb750's for many years now, and I've never been disappointed with their performance. It's just a case of fit, set, and forget. Magnificent. Cheers, Terry. 8)
elcid
« Reply #9 on: November 21, 2005, 03:58:12 PM »
I have a cb550 & there is electronic ignition for 750 on Ebay I want to buy. Will it work?
Offline Gordon
  • 750K1, 550K2
« Reply #10 on: November 21, 2005, 04:10:52 PM »
What model 750?  If it's a sohc, then they are interchangeable.
Offline Phaedrus
« Reply #11 on: November 21, 2005, 05:55:03 PM »
I know the dyna s worked for the 550 as well as the 750, a few others perhaps.
Jason
1976 CB550 - Texas
Offline Egil
« Reply #12 on: November 22, 2005, 02:48:03 AM »
If you get the newtronic system all  to :HONDA  CB350, CB400, CB500, CB550, CB750, CB750K, CB750K1 TO CB750K7  HO4  NOT CB750KZ  and the price in UK £84.30
Good luck whit your project ???
Egil.
73 de La2vpa.
Egil.
On The Edge.....That`s Where We Live Every Day.
My bike :
http://bike.no/member/photo.php?id=1605
