Author Topic: Broke slow speed jet removal  (Read 1033 times)
Offline Bosgarage57
« on: August 04, 2014, 08:12:10 AM »
Any suggestions on getting a broken slow speed jet out of a carb?
1978 CB750K
Re: Broke slow speed jet removal
« Reply #1 on: August 04, 2014, 08:15:13 AM »
some are press-fit, some are screw in.
really helps to know what carbs you have so we can give you accurate info.....
a picture would be helpful, too
« Last Edit: August 04, 2014, 08:25:22 AM by flybox1 »
Offline Bosgarage57
« Reply #2 on: August 04, 2014, 09:35:18 AM »
thatd prob help a little bit wouldn't it :)  sorry, here it is:
1978 CB750K
Offline goldarrow
  • one day, i'll be an
« Reply #3 on: August 04, 2014, 09:38:57 AM »
new carb body or left hand drill/easy out???
CB550 K0
« Reply #4 on: August 04, 2014, 09:45:03 AM »
screw out type.  PB blaster overnight to make it easier.
+1 to the easy out.  brass is soft.  go slow.
Offline Bosgarage57
« Reply #5 on: August 04, 2014, 11:03:12 AM »
been to 3 autoparts stores and they don't sell an EZout that small. guess I'll have to order one. Thanks guys.
1978 CB750K
« Reply #6 on: August 04, 2014, 11:27:09 AM »
L handed drill bit?
« Reply #7 on: August 04, 2014, 11:40:46 AM »
Is it jammed in there?
I have removed those with pin tip in a circular motion, and with a small flat blade screwdriver tapped gently into the soft brass.  The ones I removed were the result of over tightening and snapped off remains.  The remains were not stuck in the threads.
Nic
« Reply #8 on: August 04, 2014, 02:50:45 PM »
I snapped one off doing it up too tight as it seems, I made up a small screw driver tip on the bench grinder with the tip tapered a little and quite sharp, give a couple of light but firm taps with a hammer so the tip eats into the brass, it screwed right out, just be gentle.
Offline Bosgarage57
« Reply #9 on: August 05, 2014, 08:51:23 AM »
great Ideas guys thank you.  I have a couple pick tools I don't use much. I could try.
1978 CB750K
Offline lucky
« Reply #10 on: August 06, 2014, 06:59:04 AM »
Just try a small flat blade electronics screwdriver. Make sure it fits into the brass part.
