Author Topic: Firing order/Spark Plus question  (Read 1695 times)
Offline hondachopproject
« on: May 23, 2005, 02:35:43 PM »
Hello,
I got a 76 550 and need firing order...which piston is which as you set on bike?
Also have a spark plug question, as I was removing my wires during tear down to hardtail, I pulled the end off of one of the plug wires can I just slide it back on or do I nned to repalce plug or whole cil to fix the problem?
Thanks for the help,
Lee
« Last Edit: May 23, 2005, 02:37:36 PM by hondachopproject »
92 HERITAGE
Re: Firing order/Spark Plus question
« Reply #1 on: May 23, 2005, 02:37:02 PM »
Oopps,
I mean "need to repalce plug or whole coil"
Lee
92 HERITAGE
Offline Einyodeler
  • Midnight bugs taste best!!!
« Reply #2 on: May 23, 2005, 02:47:20 PM »
Hi Lee,as you sit on the bike the left piston is #1,#2,#3 and#4 on the right.The plug caps are threaded inside so snip about 1/4" off the wires so you`ll get some fresh copper and screw it back in.
1972 CB500 - 1973 CB500 - 1974 CB550K - 1975 CB550F - 1975 CB750F - 1976 CJ360 - 1983 CR480 - 1970 BSA A65T Thunderbolt
Download Motorcycle Shop Manuals here: http://forums.sohc4.net/index.php?topic=17788.0
« Reply #3 on: May 23, 2005, 02:54:26 PM »
Hey Thanks for the info,
Will go do that now.
Thanks Again,
Lee
Kansas
92 HERITAGE
