Author Topic: Hi again  (Read 673 times)
Offline FatFreddysCat
  • the adventure goes on...
Hi again
« on: August 06, 2014, 01:40:38 AM »
It's been that long since I first visited here I though I'd say hello again. A few years ago I picked up a 77 cb550k3. Well you know the story a  hour here and there and things 'progress' fairly slowly. However things are coming back together now and I'm on the dreaded wiring job. I'm leaving out the electric starter (just keeping lights and brake lights) so was wondering where to connect the black wire from original regulator. The reading from the multi meter shows this (also white and green) as negative. Can't seem to find any reference in the search to this black wire. Any advice more than welcome  :)
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: Hi again
« Reply #1 on: August 07, 2014, 02:58:10 AM »
Come back to www.sohc.co.uk too!
I see you haven't visited for a couple of years - we have an ongoing (at the moment) debate about UK-spec wiring on 550s.
Steve
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Re: Hi again
« Reply #2 on: August 08, 2014, 01:31:29 AM »
Thanks Steve, as I say it's been a couple of years but hopefully on the home straight now - will be swinging round .co.uk too
Re: Hi again
« Reply #3 on: August 08, 2014, 01:40:23 AM »
I thought the black was needed to complete the circuit and power the white field wire back to the alternator. As Thomas  Edison said I have not failed. I've just found 10000 ways that won't work.
Re: Hi again
« Reply #4 on: August 08, 2014, 10:42:40 PM »
Any solid black wire is +12V, hot when the ignition (key) switch is on. The black wire that connected to the regulator needs to be connected to the regulator to supply the output to the white field wire.
Re: Hi again
« Reply #5 on: August 09, 2014, 02:16:10 AM »
Thanks Scottly that was what I'd imagined - just wanted to be sure . Would hate to have something melt out quietly and add to the wonder of it all. I've already spent a couple of hours just sitting looking at the wiring diagram  trying to breath it in :)
