Author Topic: cl90 Stuck Rocker Arm Shaft  (Read 1559 times)
Offline silentsvn
« on: August 07, 2014, 01:30:19 PM »
I have a CL90 motor that Im trying to bring back to life. One of the rocker arm shafts seems to be stuck on the rocker arm and wont release. There are no threads on the inside of the shaft to pull it like a bigger engine.
I have tried heat, PB blaster heaving cleaning in ultrasonic. Im okay with killing the shaft but I would like to preserve the head casting if possible.
Does anyone have any tips on getting it to release beside taking a grinder to it?
1973 Honda CB350 Four
2004 BMW GS 1150 Adventure
1967 Honda CL 90
Stuff for Sale
Offline calj737
  • I refuse...
Re: cl90 Stuck Rocker Arm Shaft
« Reply #1 on: August 07, 2014, 02:22:38 PM »
can you drop it in the freezer for an overnight? Cold may help create enough separation to allow the rocker off.
Offline silentsvn
« Reply #2 on: August 07, 2014, 02:25:09 PM »
Ya I'll try that. See what happens problem is the rocker is steel and so is the shaft so hear wasn't doing anything
1967 Honda CL 90
Stuff for Sale
