Plenty of info on doing this in the manual plus numerous threads on here about it. It's not hard, it's tricky.
Assuming your wheels are spoked, there's a retainer ring that needs to be drilled to remove the stakes, then unscrew the ring. Other side of front is left threaded if I recall correctly. Consult a manual for proper steps and assembly pattern.
